What software can I use to convert my bmp images to mpeg?
if you want to string a bunch of bmps together to make a real mpg, i suggest a program called videomach. it can take bmps, other mpgs etc and make them to mpgs. it allows lots of control, in terms of order, framerate, how many frames for each bmp etc. i usually output to high res very high bitrate (lik 10mbps) mpg1 and then re-encode to mpg2 (so i don't lose any quality in the transfer).
also, if you can get a copy of adobe premiere, you can use the timeline (very poiwerful) and export with cce plugin.
How to Convert a Unicode SRT file to bmp or idx
By rezabrando in forum SubtitleReplies: 12Last Post: 19th Jun 2015, 11:15 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
how do i insert a title frame (e.g. a mpeg, bmp or gif)
By eduardo0701 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2010, 10:20 -
how to convert BMP to AVI ?
By monks19 in forum Video ConversionReplies: 2Last Post: 2nd Apr 2010, 16:08 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
