my panasonic F65 5-disc region 1 dvd player has decided that it won't play any of my DVD's anymore after I played a few VCD's. It keeps telling me that the DVD I put in has the wrong region coding. VCD disc still play fine. Anyone know if there's a way to reset it so it will be able to read DVD again?
Try resetting dvd player, some time that helps. I would look on Panasonic's website. They have online manual so find one for your player and see if you can reset to factory help-B
i have the operating manual but it doesn't have any information on how to reset to factory setting
I have attached procedure from my manual. Try that and see if it works-B
Ok- It is .gif file and I try to attached with this message but was not able to . Can some one tell me how to insert .gif image? I saw the instruction in the bottom but was not succesfull. I also tried to browse but no luck- may be I am missing something here-B -
if possible, please send the gif image to my e-mail vhtung@earthlink.net
many thanks -
thanks Bhola but resetting didn't help. i guess i'll have to bring it to a service center. too bad i threw away the receipt so now i'll have to pay for the service
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
Windows Media Player Won't Play DVDs Anymore
By Card Shark in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2010, 19:04 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 17:44 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 05:20 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jul 2007, 00:08
