Can you please advise me on which DVD-ROM's on the market are able to be made Region Free.
As I am having difficulty decifering which reliable products have firmware to unlock the regions perminately.
Pete
Results 1 to 9 of 9
Here's a good website for the type of information you seek. Hopefully soon someone from this board will share their successful region free experiences with their specific player - in the meantime check out this site.
http://forum.rpc1.org/portal.php -
A good many DVD-ROM drives can be made region free these days, however if you're looking for a recommendation I'd throw my Lite-On into the mix.
When I was looking to replace an old Matsushita that couldn't read recordable DVD media, the Lite-On's had a number of things going for them:
1. Some can be software toggled if you don't want to invalidate your warranty.
2. Lots of firmware hacks for the Lite-On's per se - obviously a popular range of drives or very easy to locate the region coding in the EPROM.
3. Phenominal ripping speeds compared to some... these things move !
4. Cost.
I got a 165 for about £25, which is a bit of a bargain IMHO. It works very well and I freely recommend it. -
There are two program that make your dvd-rom drive region free.
http://www.slysoft.com/
http://www.dvdidle.com/ -
Hi, as well as hardware check out some software. I typed "dvd region free" in Google (www.google.com - excellent search engine if you've not discovered it) and it brought back some results that could be of use to you.
I personally use DVD Region Free on my PC(http://www.dvdidle.com/download.htm) without any problems.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Oh yes, you will probably require something like DVD Genie if you're planning on using multiple region discs with PowerDVD / WinDVD etc...
LG ht904ta dvd player regional free code
By Mwilamj in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2010, 01:49 -
LG HT963TA DVD regional code unlock?
By Reasoner in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Jan 2010, 21:54 -
Region Free for TSSTcorp DVD-ROM TS-H352C
By hufaunder in forum Newbie / General discussionsReplies: 3Last Post: 6th Dec 2008, 19:10 -
how to make dvd-rom region free?
By ieh4f in forum ComputerReplies: 6Last Post: 29th Jun 2008, 15:24 -
free software for making cd-rom iso's
By Dr.Gee in forum ComputerReplies: 1Last Post: 27th May 2008, 19:00
