  1. I have an hour long VCD video but I only want like 5 minutes of a segment. How do I edit the dat file on the VCD? thx for any info guys!
  2. You need to convert it back to a MPEG1 file. You can do this with either VCDGear or VCD Easy (under tools VCDxRip). Once you have the MPEG1 file you can edit as desired (eg. VDub).
  3. wow thanks a lot for the fast response! after i convert it, can i use premiere to edit?
  4. *.DAT file is already MPEG-compliant. You can use it directly in any cutting software. You open this DAT file like a regular MPEG file and cut. The easiest way would be using TMPGEnc (Look at this guide). You certainly can edit either DAT file or converted file with any editing software.
  5. hey cool, thx. it worked!
