HELP! There are a couple of posts pending an answer on how to convert PAL to NTSC. Anyone? Thanks
Try using TMPGEnc its a good program that should allow you to convert frm one format to another. There may be slight encoding problems with the film though.
To find out about the screen sizes and refresh rates (25 for PAL, 30 for NTSC) look at the WHAT IS section and select what you want to create. i.e for A VCD choose VCD::
https://www.videohelp.com/vcd
Best thing is to Download the freeware version (does have slight limitations) of TMPGEnc and use that.
~ https://www.videohelp.com/forum/viewtopic.php?t=175169 ~ -
Thank you for the reply Phunkie Munky. I tried searching for which I found Virtual Dub and VcdGear, I've also tried TMPGEnc. None work. It's ok though, I'm going to take the player back now and get one that will play everything. I'm looking at an APEX from CC I suppose.
CHEERS -
DO NOT GET AN APEXOriginally Posted by thatcoolguy
Get the Cyberhome CH-DVD 500
You can order it direct from the CYBERHOME WEBSITE for $79.95 US Dollars + shipping.
The Cyberhome CH-DVD 500 is the BEST stand alone DVD player for doing PAL to NTSC conversions.
It can be made region free very easily with a secret code you simply punch on the remote control. For more info about this visit the CYBERHOME forum on the message forums at the NERD-OUT WEBSITE
As far as doing PAL to NTSC conversion on your computer using TMPGEnc then here is the info you will need:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=
Either way you go ... good luck
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
