I just used BeSweet for the first time and I converted my .wav file to .ac3. When I play the DVD back through my standalone the audio is very low. I made a 2nd DVD (RW) using the .wav file and the audio is normal. Is there something I'm doing wrong?
ChachiFace
no, this seems to be fairly normal for .AC3 to be quieter than .WAV
The only thing to check is if your DVD player has Audio DRC turned on in the setup menu. if it is, turn it off.
It's designed to supress the audio to sound better on a TV, at a more constant level. in practice it doesn't seem to work very well, and is just annoying. -
I don't see how people can say there is very little difference between the quality of AC3 and PCM. The audio I hear from AC3 is hollow, low, and almost empty compared to the uncompressed PCM.
If someone has figured a way to convert PCM to AC3 and still keep the same quality (treble, bass, volume). Let me know what the formula is. I just can't see going to AC3 from PCM.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 04:16 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
