I have a small video that will fit on a cd using dvd compresion. I currentlly distribute it on dvds so my clients can see it on their dvd players.
My question is : Can the small dvd data be saved on regular cd so it can be played as it it was a dvd on standard players?
it's called miniDVD.
Doesnt work on most DVD players.
Take a look at the guides.THIS has been an RVL123 production... -
Have wrestled much with this issue.
MiniDVD (MPEG-2) plays on about 5% (or less) of Standalones, or a PC, IF it has an MPEG-2 player installed. Same video quality as DVD, much cheaper. Note that 'IF'. Many PC's do NOT have the necessary software, though most do have the hardware.
CVD or SVCD (MPEG-2) play on 60-80% of Standalones, PC same as MiniDVD. Video quality slightly lower, perhaps unnoticeably so.
VCD (MPEG-1) plays on almost all Standalones, and virtually ANY PC, with no additional software required. Guess what? It looks like crap, although some video can be made to look fairly decent, basically with blurring filters.
If a high percentage of your target market has PC's, AND you need higher quality than VCD can deliver, consider a HI-bitrate, Hi-resolution MPEG-1 video, which will play with built-in software on anything with Win95 or better installed. You can even make it autorun. Beware complex menus, these can be problematic on PC playback. These disks will play in a fair number of Standalones, as well.
SVCD with an on-disk, freeware, no-installation-necessary player would be a good option, I never found workable software. There are some that will work, but an installation is required, typically with reboot. Too invasive for my needs. I ended up using 720x480 MPEG-1 @ 3500 bitrate, tweaked the autoplay for 98 and NT, worked well.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 06:06 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
