  1. I just got my Pioneer 106 burner and the first disc, a Platinum DVD+R 2.4 speed worked just fine, and I used CloneDVD.
    So, I got really happy and burned another one, using same software, and same brand of discs. Writing went fine and I got a "DVD created" message. However the disc won't play and doesn't even get recognized by the computer!! I've produced three coasters now and every time CloneDVD tells me that the process went through fine!?!?!?
    What the hell is wrong here?
    /Toby
    Apr 2002
    The State of Frustration
    I have not used CloneDVD, so feel freee to view what I say say with askance. First, go to DVD+RWs until you solve this issue. And see if you have a simulate burn option on your program as well.
    Hello.
    May 2003
    It truly is a media issue I always use a rw to test the burn then I use a dvd- +r then so try this first I hope it helps I had the same problem in the first days of getting my clone dvd program also.. I use tdk or fuji dont use junk and you will always get a good backup ..
