okay, what i think is a simple question
i'm trying to use tmpge version 2.53 to take out commercials of a show that I recorded
I use tmpge and then cancel wizard when it comes up and go to file, mpeg tools and then the far right column where it says merge and cut. I'm able to successfully take out on commercial and then it brings me back to the main screen where i have the options to add, delete, clear and edit. what do I do from here? I want to take out all the commercials and it seems as if it is only allowing me to do 1.
thanks for any assitance
bt
Actually, you are doing fine. Just think about the "big picture". You cannot just edit from one video but as many as you like. If you want to edit one video, fine. Just once you have selected you first cut, go back, select your same video again and select your next cut. Repeat until you have selected all the scenes you are going to keep. Then name the final cut video, and select Run. So right below you select run, you Merge & Cut Tool may look something like this:
Hello.
Audio during commericals, none during show in RipBot264
By tsservo in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2011, 04:43 -
VideoReDo doesn't Save/Output entire file after editting out commericals
By peter11815 in forum EditingReplies: 1Last Post: 19th Sep 2009, 14:41 -
Question about how to keep Quicktime from taking over Firefox
By jimdagys in forum ComputerReplies: 5Last Post: 7th Sep 2009, 00:59 -
Automatically adding your own commericals in live feed
By Jutboy in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2008, 16:35 -
How do i author dvd menu with chapters + cut commericals...with a WMV??
By chocolate_brownie in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2007, 19:00
