Results 1 to 16 of 16
    Nov 2002
    Los Angeles, CA
    Hi everyone,
    I have tried everything I can think of to convert my XViD AVI files into Toast-ready VCD MPG files. These AVI files can be watched on my computer but I would much rather have them able to be watched on my TV through my DVD player. FFMPEGX won't convert it correctly, and I tried to use mencoder cli as suggested by the post found at https://www.videohelp.com/forum/viewtopic.php?t=137015&highlight=xvid but that just makes the files go from 180 mb each to around 380 mb each and will not help the conversion. Then today I tried the DIVXWMAConverter program and the outputted file didn't have sound and when I put it into DiVX Doctor II the output file was practically a green screen with sound that crashed Quicktime after a few seconds. Maybe I am forgetting something in FFMPEGX, but any help at all would be greatly appreciated!
    Thanks,
    Wolfwood87
    Feb 2003
    Bloomington-Normal
    i can help you with this. I need to know what your settings are in ffmpeg, and what the terminal output was.
    No matter what audio codec it is in, it is workable.
    Nov 2002
    Los Angeles, CA
    Thanks for your reply ZeroSix and I am very sorry for my late reply. Anyway, I would appreciate any help that you could give me. I took my XviD file and I am converting it to VCD using ffmpegX v.0.0.7d My settings were set by using the VCD NTSC setting from the Quick Presets menu. Then, the only settings that I changed were under the Tools menu:
    Author to VCD - I will add my own chapters later so i don't wnat to hhave it in the .bin format
    Split in "2" chunks - It is small enough that it doesn't need to be split
    This should be all that I changed. Just for reference, all of the options under the "Options" menu were not checked except for Constant Bitrate. ffmpegX says that my XviD file is :
    VIDEO: [XVID] 640x360 24bpp 23.98 fps 876.5 kbps (107.0 kbyte/s)
    in the area above the "Open..." button. I am encoding it right now, so thus far I only have this for the output in the terminal:
    Last login: Wed Aug 27 16:06:31 on ttyp2
    pbpaste | sh
    Welcome to Darwin!
    [Delgamo:~] dave% pbpaste |sh
    Encoding started on Wed Aug 27 18:51:36 PDT 2003
    Input #0, avi, from '/Volumes/Big Mama/Lanfill Folder/Conversions..../LE - 02.avi':
    Stream #0.0: Video: mpeg4, 640x360, 23.98 fps, 800 kb/s
    Stream #0.1: Audio: mp3, 44100 Hz, stereo, 112 kb/s
    Output #0, yuv4mpegpipe, to 'pipe:':
    Stream #0.0: Video: rawvideo, yuv420p, 352x240, 29.97 fps, q=2-31, 200 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Press [q] to stop encoding
    frame= 3461 q=0.0 size= 438099kb time=118.6 bitrate=30384.1kbits/s
    Sorry I can't be of more help right now, but when I finish (which may be a WHILE because I am encoding on a G3) I will post the rest of the Terminal output.
    Thanks,
    wolfwood87
  4. Anonymous
    Guest
    If you have Toast, do this:
    Take your original AVI file and drop it on Divx Doctor and convert it to a .mov.
    Use Toast in the VCD heading to convert the .mov file created before to an VCD. Thats it.
    If your AVI had AC3 audio then DIvx Doctor won't work on it. It willl get more complicated again. ZeroSix has the way to do it if this does'nt work. Good Luck!!
    Nov 2002
    Los Angeles, CA
    Hi,
    Unfortunately I wasn't able to complete the encoding last night, but I will do it tonight and post the results tomorrow if everything goes according to plan. Thanks for your advice JellyBean, and what you said is what i normally do for my AVIs, but these XviD files must have the wrong audio because when I convert any of them in DivX Doctor II it just gives me a green screen and then quits out of Quicktime. And, I have one correction to make, if it makes any difference. In my initial posting I stated that the mencoder cli didn't do anything besides increase the file size. Well, I didn't mention that it allows the audio to be played, which is helpful but doesn't help with the VCD part as far as I can tell.
    Anyway, thanks to the both of you and I will post my results as soon as I can.
    Thanks,
    wolfwood87
    Nov 2002
    Los Angeles, CA
    OK, now I have my latest results. I used the same options in ffmpegX as yesterday, and this is what I got:
    Last login: Thu Aug 28 17:14:22 on ttyp2
    pbpaste | sh
    Welcome to Darwin!
    [Delgamo:~] dave% pbpaste | sh
    Encoding started on Thu Aug 28 17:20:55 PDT 2003
    Input #0, avi, from '/Volumes/Big Mama/Landfill Folder/Conversions..../LE2.avi':
    Stream mapping:
    Stream #0.0 -> #0.0
    frame=35000 q=0.0 size= 4331489kB time=1167.8 bitrate=30384.1kbits/s
    ++ WARN: [mpeg2enc] Error reading frame header (17): codeunknown error code!
    Output #0, mp2, to '/Volumes/Big Mama/Landfill Folder/Conversions..../LE2.mp2':
    Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    size= 39915kB time=1459.7 bitrate= 224.0kbits/s
    INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
    INFO: [mplex] File /Volumes/Big Mama/Landfill Folder/Conversions..../LE2.m1v looks like an MPEG Video stream.
    INFO: [mplex] File /Volumes/Big Mama/Landfill Folder/Conversions..../LE2.mp2 looks like an MPEG Audio stream.
    INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
    INFO: [mplex] Selecting VCD output profile
    INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Big Mama/Landfill Folder/Conversions..../LE2.m1v)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 352
    INFO: [mplex] Frame height : 240
    INFO: [mplex] Aspect ratio : 1:1 (square pixels)
    INFO: [mplex] Picture rate : 29.970 frames/sec
    INFO: [mplex] Bit rate : 1152000 bits/sec
    INFO: [mplex] Vbv buffer size : 40960 bytes
    INFO: [mplex] CSPF : 1
    INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Big Mama/Landfill Folder/Conversions..../LE2.mp2)
    INFO: [mplex] AUDIO STREAM:
    INFO: [mplex] Audio version : 1.0
    INFO: [mplex] Layer : 2
    INFO: [mplex] CRC checksums : no
    INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [mplex] Frequency : 44100 Hz
    INFO: [mplex] Mode : 0 stereo
    INFO: [mplex] Mode extension : 0
    INFO: [mplex] Copyright bit : 0 no copyright
    INFO: [mplex] Original/Copy : 1 original
    INFO: [mplex] Emphasis : 0 none
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 1412000
    INFO: [mplex] target data-rate specified : 1411200
    ++ WARN: [mplex] Target data rate lower than computed requirement!
    ++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate
    ++ WARN: [mplex] streams is common and harmless provided no time-outs will occur
    INFO: [mplex] Sectors = 18 Video delay = 21600 Audio delay = 21600
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 47104 frame=000000 sector=00000000
    INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [mplex] Padding : sector=00000000
    INFO: [mplex] Scanned to end AU 34999
    INFO: [mplex] STREAM e0 completed @ 34999.
    INFO: [mplex] STREAM c0 completed @ 55880.
    INFO: [mplex] Multiplex completion at SCR=131427600.
    INFO: [mplex] Video e0: buf= 47104 frame=034999 sector=00072978
    INFO: [mplex] Audio c0: buf= 1171 frame=055880 sector=00017935
    INFO: [mplex] Padding : sector=00018578
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 21001442 bytes
    INFO: [mplex] Sequence headers: 2452
    INFO: [mplex] Sequence ends : 1
    INFO: [mplex] No. Pictures : 35000
    INFO: [mplex] No. Groups : 2452
    INFO: [mplex] No. I Frames : 2452 avg. size 12386 bytes
    INFO: [mplex] No. P Frames : 9216 avg. size 5714 bytes
    INFO: [mplex] No. B Frames : 23332 avg. size 3642 bytes
    INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
    INFO: [mplex] Average bit-rate : 1150800 bits/sec
    INFO: [mplex] Peak bit-rate : 1275200 bits/sec
    INFO: [mplex] BUFFERING min 31 Buf max 32306
    INFO: [mplex] AUDIO_STATISTICS: c0
    INFO: [mplex] Audio stream length 40872960 bytes.
    INFO: [mplex] Syncwords : 55881
    INFO: [mplex] Frames : 31932 padded
    INFO: [mplex] Frames : 23949 unpadded
    INFO: [mplex] BUFFERING min 15 Buf max 746
    INFO: [mplex]
    INFO: [mplex] MUX STATUS: no under-runs detected.
    Encoding completed on Thu Aug 28 20:24:43 PDT 2003
    Looking through the code, it says that an error was found somewhere in the video. Then, I looked at the actual outputted file. It took an unusually long time to come up in Quicktime, and video seemed to not be in sync with the audio. So I went into MpegInfo and It showed that the video was about 4 mins shorter than the audio. So, I don't know what to do. Is it this specific file? What causes this? Thanks in advance.
    wolfwood87
    Feb 2003
    Bloomington-Normal
    Send me a clipping of your .avi file using the method described in the thread about the DishRip.
    I will take a close look at it and see what I can come up with.
    Nov 2002
    Los Angeles, CA
    ZeroSix,
    The file should be uploaded to your iDisk account. It is a 15 sec clip of my original avi file. I had made a 30 sec clip but it was too big for your account, but if you need it and can get rid of about 1 megabyte I can upload that as well. Thanks for your help.
    wolfwood87
    Feb 2003
    Bloomington-Normal
    i got your file, but i am getting NO audio from either QUICKTIME or VLC. Does this file have audio?
    Nov 2002
    Los Angeles, CA
    ZeroSix,
    No, this file as well as the other files in this series don't seem to play any audio in Quicktime or in VLC. One thing I did notice that I mentioned earlier however was when I did the conversion in mencoder cli it made the files audible. I can give you a clip of the same file but converted so that you can listen to the clip as well if thats what you need.
    Thanks,
    Wolfwood87
    Feb 2003
    Bloomington-Normal
    Strange... I cant get any audio out of the file using Mencoder and I cannot get it to detect any audio. There is no audio in Quicktime, VLC, Mplayer. I tried using the AVI demuxer of MediaPipe and it reports no audio. What format is it in?!?
    If you could send me a clip with a converted audio stream it would be appreciated.
    Nov 2002
    Los Angeles, CA
    Yes, it is strange.... Can Quicktime and VLC normally play XviD files with sound? Anyway, I uploaded a 30 sec clip with sound to your iDisk. The best of luck to you!
    Thanks,
    Wolfwood87
    Feb 2003
    Bloomington-Normal
    Quicktime and VLC should be able to as well as Mplayer. I did get this to work though using ffmpegX.
    Using the .avi file you gave me with sound, here are my settings:
    Set up ff to those exact settings and you should be fine. If you have a DVD player that doesnt support 23.98 fps VCDs, let me know and I will show you how to apply a 3:2 pulldown to change the framerate to 29.97.
    Hope this helps.
    Feb 2003
    Bloomington-Normal
    Furthermore, here is the output ff gave me:
    Encoding started on Sat Aug 30 16:06:35 CDT 2003
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    Input #0, mov, from '/Users/tyler/Desktop/le2withsoundclip.avi':
    Stream #0.1: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
    Stream #0.0: Video: rawvideo, yuv420p, 352x240, 23.98 fps, q=2-31, 200 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    frame= 736 q=0.0 size= 91085kB time=30.7 bitrate=24307.3kbits/s
    **ERROR: [yuvscaler] Couldn't read frame number 736!
    RESET 0 52 err:0
    CODECID 30 31 twos
    This file was encoded with libavcodec build 4660
    Output #0, mp2, to '/Users/tyler/Desktop/le2clip2.mp2':
    Stream mapping:
    Stream #0.1 -> #0.0
    size= 840kB time=30.7 bitrate= 224.0kbits/s
    INFO: [mplex] File /Users/tyler/Desktop/le2clip2.m1v looks like an MPEG Video stream.
    INFO: [mplex] File /Users/tyler/Desktop/le2clip2.mp2 looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (/Users/tyler/Desktop/le2clip2.m1v)
    INFO: [mplex] Picture rate : 23.976 frames/sec
    INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/tyler/Desktop/le2clip2.mp2)
    INFO: [mplex] Scanned to end AU 735
    INFO: [mplex] STREAM e0 completed @ 735.
    INFO: [mplex] STREAM c0 completed @ 1175.
    INFO: [mplex] Multiplex completion at SCR=2817600.
    INFO: [mplex] Video e0: buf= 41867 frame=000735 sector=00001785
    INFO: [mplex] Audio c0: buf= 1901 frame=001175 sector=00000378
    INFO: [mplex] Padding : sector=00000153
    INFO: [mplex] Video Stream length: 512876 bytes
    INFO: [mplex] Sequence headers: 52
    INFO: [mplex] No. Pictures : 736
    INFO: [mplex] No. Groups : 52
    INFO: [mplex] No. I Frames : 52 avg. size 9438 bytes
    INFO: [mplex] No. P Frames : 195 avg. size 6702 bytes
    INFO: [mplex] No. B Frames : 489 avg. size 4724 bytes
    INFO: [mplex] Average bit-rate : 1069200 bits/sec
    INFO: [mplex] Peak bit-rate : 1132400 bits/sec
    INFO: [mplex] BUFFERING min 31 Buf max 16539
    INFO: [mplex] Audio stream length 860160 bytes.
    INFO: [mplex] Syncwords : 1176
    INFO: [mplex] Frames : 672 padded
    INFO: [mplex] Frames : 504 unpadded
    INFO: [mplex] BUFFERING min 15 Buf max 744
    INFO: [mplex]
    Encoding completed on Sat Aug 30 16:07:21 CDT 2003
    Nov 2002
    Los Angeles, CA
    THANK YOU ZEROSIX!!
    I tried your settings on the test clip and they worked perfectly, thank you so much! I thought I would never be able to encode them, but a solution has been found!! I will try that whole file tonight and post my results tomorrow or as soon as possible. One question though, is this possible without the use of mencoder cli or is another option available for a quicker way to do the same job that mencoder does to the file? Just curious, definitely not a necessity for you to find the answer to if you don't happen to know already.
    Thank you very much,
    Wolfwood87
    Nov 2002
    Los Angeles, CA
    I did the conversion last night, and it worked perfectly! Here is my ffmpegX output:
    Last login: Sun Aug 31 00:04:20 on ttyp4
    pbpaste | sh
    Welcome to Darwin!
    Encoding started on Sun Aug 31 07:12:01 PDT 2003
    Input #0, avi, from '/Volumes/Big Mama/User disk/Dave/Anime Files/New Episodes/le3.avi':
    Stream mapping:
    Stream #0.0 -> #0.0
    frame=35121 q=0.0 size= 4346464kB time=1464.8 bitrate=24307.3kbits/s
    **ERROR: [yuvscaler] Couldn't read frame number 35121!
    Output #0, mp2, to '/Volumes/Big Mama/Landfill Folder/Conversions..../le3.mpg.mp2':
    Stream mapping:
    Stream #0.1 -> #0.0
    size= 40054kB time=1464.8 bitrate= 224.0kbits/s
    INFO: [mplex] File /Volumes/Big Mama/Landfill Folder/Conversions..../le3.mpg.m1v looks like an MPEG Video stream.
    INFO: [mplex] File /Volumes/Big Mama/Landfill Folder/Conversions..../le3.mpg.mp2 looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Big Mama/Landfill Folder/Conversions..../le3.mpg.m1v)
    INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Big Mama/Landfill Folder/Conversions..../le3.mpg.mp2)
    INFO: [mplex] Scanned to end AU 35120
    INFO: [mplex] STREAM e0 completed @ 35120.
    INFO: [mplex] STREAM c0 completed @ 56074.
    INFO: [mplex] Multiplex completion at SCR=131881200.
    INFO: [mplex] Video e0: buf= 25228 frame=035120 sector=00091295
    INFO: [mplex] Audio c0: buf= 438 frame=056074 sector=00017997
    INFO: [mplex] Padding : sector=00000577
    INFO: [mplex] Video Stream length: 26279061 bytes
    INFO: [mplex] Sequence headers: 2463
    INFO: [mplex] No. Pictures : 35121
    INFO: [mplex] No. Groups : 2463
    INFO: [mplex] No. I Frames : 2463 avg. size 14052 bytes
    INFO: [mplex] No. P Frames : 9245 avg. size 7240 bytes
    INFO: [mplex] No. B Frames : 23413 avg. size 4642 bytes
    INFO: [mplex] Average bit-rate : 1148000 bits/sec
    INFO: [mplex] Peak bit-rate : 1196400 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 33745
    INFO: [mplex] Audio stream length 41014858 bytes.
    INFO: [mplex] Syncwords : 56075
    INFO: [mplex] Frames : 32042 padded
    INFO: [mplex] Frames : 24033 unpadded
    INFO: [mplex]
    Encoding completed on Sun Aug 31 13:29:52 PDT 2003
    Thanks to everyone involved, especially ZeroSix.
    Thank you,
    Wolfwood87
