o.k well i never has this problem before.
i can open up the program and go through the wizard but once it suppose to start encoding i get an error message saying that there was an error and that my program is going to be closed. and then it closes.
the other intresting thing is that if i clilck on SOURCE RANGE (just to see if i get to see any of the movie images) the same error happens and the program closes again.
after this happened i thought that there might be a problem with the program itself so i tried to load other .avi files to see if they encode and it worked perfectly.
so i figured, well, there must be something wrong with that specific file then...so i loaded it unto DivxFix. Striped the index rebuild it, checked for errors ...the whole deal......
but that DIDN'T WORK EITHER....
this is getting really frustrating
any ideas out there....
(im using windows 2000, P4 1.4ghz, 600 Ram)
thanks
Results 1 to 9 of 9
o.k here is the info:
FILE
Path=c:\movie
size=409MB
status=file length correct
VIDEO FORMAT
Codec
4CC=MP43
name=S-Mpeg 4 version 3
status=Codec is installed
aspect=480 x 280 (1.714 : 1)
bitrate=534 kb/s
framerate=23.976 FPS
duration=01h 29m 59s
STREAM TYPE AND A/V INTERLEAVE
type=OpenDML AVI
I/L=1 frame (42 ms), p=504
IMRR=1.00
AUDIO FORMAT
codec
name=0x0055(MP3) ID'd as MPEG-1 Layer 3
bitrate=96 kb/s (48/ch x 2 ch) CBR
Fs=48000 Hz
COMMENTS / METADATAcode=junk
name=ASCII in junk chunk
contents=VirtualDub build 0
code=junk
contents=release
DIRECTSHOW RENDERsource=MEDIASUBTYPE_Avi
video media=WMMEDIASUBTYPE_MP43
audio media=WAVE_FORMAT_MPEGLAYER3 (MP3) (0x0055)
splitter/other=AVI Splitter
video codec=Mpeg43 Decoder DMO
audio codec=MPEG Layer-3 Decoder
status=file rendered successfully, no errors occured
o.k thats all of it...
i should mention that the file plays flawlessly on wmp
thanks again -
Go to the environmental settings in TMPG and make sure the AVI2(OpenDML)File Reader has a priority of at least one. See if that helps.
o.k i tried that but nothing happened...
here are my VFAPI settings in case this helps:
DIRECT SHOW MULITMEDIA FILE READER = 4
AVI2 (OPENDML) FILE READER = 0 (note: this is the one where i changed per your suggestion to +1 and even +2 and it still didn't work)
BMP/PPM/TGA/JPG FILE READER = 0
WAVE FILE READER = 0
TMPGENC PROJECT FILE READER 2.56 = 0
AVI VFW COMPATABILITY READER = -2
DVD2AVI PROJECT FILE READER 1.76 = -2
thanks -
O.K YOU'RE NOT GOING TO BELIEVE THIS BUT I SOLVED THE PROBLEM
I DIDN'T CHANGE ANY OF MY ORIGINAL SETTINGS
I DIDN'T RUN DIVXFIX AGAIN....
ALL I DID....WAS:
RENAME THE STUPID FILE EXTENSION FROM .AVI TO .ASF
I CAN'T BELIEVE THAT SOMETHING SO SMALL AND STUPID WAS THE CAUSE FOR THE WHOLE PROGRAM TO SHUT DOWN....UNBELIEVABLE...
NOW...DOES ANYONE HAVE AN EXPLENATION FOR THIS?
I HAVE NO IDEA HOW THIS WORKED JUST THAT ...IT DID....
IM CURIOUS TO KNOW IF ANYBODY HAS ANY THEORIES OUT THERE...
OH AND BY THE WAY....THE IDEA TO RENAME THE FILE CAME TO ME FROM ANOTHER POSTING THAT HAD NO REAL CONNECTION TO MY PROBLEM BUT SINCE I WAS DESPERATE....
ANYWAY...THANKS YOU GUYS FOR YOUR SUGGESTIONS...
AND AGAIN ...DOES ANYONE KNOW WHY THE NEW FILE EXTENTION MADE ALL THE DIFFERENCE? -
Did ure movie play ok in software players after renaming it or was it a 'wrong format' or summin? I am having a similar problem, but the .asf plan didnt work!!
ImgBurn closes itself seconds after being open
By massner in forum Newbie / General discussionsReplies: 7Last Post: 29th Feb 2012, 20:34 -
Windows Explorer closes and restarts
By WinSpecToR in forum ComputerReplies: 5Last Post: 6th Dec 2010, 11:46 -
CamStudio suddenly closes
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2010, 08:40 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42 -
Window Closes When Back Button is Hit
By kerrex_2006 in forum ComputerReplies: 0Last Post: 8th Jun 2007, 12:01
