hey im having a problem with nero every time i go to burn a audio cd it comes up and says driver is in use in another application but i dont have any other programs running could someone tell me what to do to get it working
thanks alot
Staind // 14 Shades Of Grey // Buy It
Actually it is! There a driver called AMAPI that is used by certain programs that incorporate "BURNING" functions. As long as it is activated, it is running in the background. This problem seems to be taking place with NERO 6. If you are using an erlier version of NERO then I really don;t know what is wrong. The problem is I forgot how to disable that damn driver. Maybe someone can tell yoou how it is done. The easiest way is to do as I have and go back to NERO 5*** Latest Version was 5.5.10.50 I believe.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
So do you see Imapi running ?
Programs which use this that you would not think are music players such as real one or musicmatch. Close these down and then try.
or
Before you load nero load up task manager and check under processes see if you can see imapi running and if so end it and then start nero. This should sort your problems out. -
@hardcoreruss
i tryed the imapi idea. it is not running until i go to burn a disc. no media player is running. still say drive in use by another program.
any other idea
the rewriter is a hp dvd writer dvd 300I
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
probelm converting .mov to .avi
By Derrydoc in forum Video ConversionReplies: 3Last Post: 28th May 2011, 17:10 -
Synchronization Probelm with Dolby Digital EX Audio, Help!!
By caesarhawy in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2009, 08:35 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10
