I recently bought the Sony DRU-510A recorder and have been having trouble trying to make a DVD of my favorite 'scenes' from my DVD collection. I've been using Easy CD Creator 6 and their DVD Builder software, along with VOB files ripped using DVD Decrypter and Smart-Ripper. The problem is, every time I try to bring in a VOB file to my 'project' in DVD Builder, the system tells me it can't handle the AC-3 encoding and, when I burn a DVD+RW disc, the 16x9 image is lost (back to pan & scan or basic letterbox) and there is no audio whatsoever.
What I'm trying to do is simply pull 'scenes' from DVDs from my collection and retain the exact same picture (16x9, etc.) and sound (5.1 or whatever) quality. Is there any way to do this? Thanks in advance for any help you can provide!
-Frank
kolchak@ameritech.net
Results 1 to 11 of 11
try advanced authoring programs... DVDmaestro, Scenarist, DVDlab (free trial)
Demux the audio and video and then author them with some good authoring program... -
Without a doubt, try DVLAB, let it demux the vobs and go from there. It's an excellent program.
I just did this over the past couple of days.
I determined which vob file had the scenes I wanted (used "Play Media File" in PowerDVD), then I used ChopperXP to cut the vobs down to just the footage I wanted.
I "Saved As" a new file from Chopper, then imported those vobs into DVD Lab without demuxing.
Made my menus, compiled & burned. The only problem I have is on scenes that spanned more than one vob, I get a little hitch where the first vob ends and the second begins.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
By far the easiest way I know is to use TMPGEnc DVD Author. No messing with VOBs, demuxing, etc. Just open each DVD, use the cutting tools to chop out the piece you want using the preview window, and assemble the pieces together. You can easily make a menu of all the clips with a few mouse clicks. The program is not free but worth every penny if you plan to do this a lot. There is a fully functioning 30 day trial for download.
Morloc -
Housepig,
DVD Lab can join those broken up VOB's into a new one so you don't get that glitch.
Also, isn't there a program called "VOB Joiner"?
I'm sure, I was just doing some quick-&-dirty compilations, nothing critical.
if you can hip me to the process in DVD Lab, I'd appreciate it, and I'll take a look for Vob Joiner.- housepig
Housepig Records
out now:
Originally Posted by housepig
Select "Join VOB's" and it will find VTS_01_2.VOB automatically.
You need the very latest beta, or the latest Non-beta for this to work. In the last several betas this feature was broken.I don't have a bad attitude...
Life has a bad attitude! -
OK, I've tried using DVD Author and it seems to be pretty straight forward and the type of program that I'd easily pay for. BUT, I'm having major trouble trying to edit scenes. When I get to the area where I'm supposed to be able to cut, edit, etc.... I don't see any screen shots, just a bunch of garbled screens, like the image didn't come across. I'm thinking this may be a problem somewhere in my system, as I'm also unable to play VOB files (via Windows Media Player) directly from my DVD drive - the picture and sound skip and the screen flickers like a VHS tape with the tracking off. Anyone have any idea what I can do to correct this? At times, I'm also unable to play any compressed video files (MPG) with Windows Media Player, yet this can be resolved by rebooting my PC, after which it works again, but just for a while.
I'm running Windows 2000 with a 2.4GHz Intel, 512MB and a GeForce 4200 128MB card with the latest drivers. This would seem to be enough to get the job done, right? -
To Morloc:
Have tryed this too, but two things happened: 1) When I try to edit (set start/end points) the frames only "glitches"/no preview - just a lot of colorbars and 2) No sound.....
Anything I do wrong ??? -
That is what I am seeing also, just 'glitches', and I'm unable to make any edits to the video.
Are my PCs too old for the latest & greatest processors?
By siratfus in forum ComputerReplies: 30Last Post: 5th Oct 2009, 05:01 -
DVD Ripping and Missing Scenes
By dimpayne in forum Newbie / General discussionsReplies: 11Last Post: 6th Dec 2007, 12:24 -
Best Scenes for a Demo DVD??
By mpalm887 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2007, 14:31 -
How to make a DVD with different movies scenes?
By aplaza in forum Authoring (DVD)Replies: 3Last Post: 24th Aug 2007, 23:41 -
THE latest greatest word
By RabidDog in forum Off topicReplies: 2Last Post: 20th Jul 2007, 00:22
