I've successfully created 5 vts files in svcd2dvd (5 ep. of band of brothers) clean and with no error reported. But when i test the output with powerdvd it says error 89030000 unknown file format. i should mention that earlier tries have gone wrong cause of a bad file (ep.04 replacements) witch i've replacedand should be okay ! do anyone have any clues ? please help.
LateEntry
Results 1 to 9 of 9
adi_001Guest
i'm also experiencing this exact same problem... it has only occured since my last update, but i believe chrissyboy IS aware of it tho...
hmm, it's funny i didn't see that two of my files were pal and the other three were ntsc. i replaced the the pal files with ntsc and everything worked great, but shouldn't this new version support both pal and ntsc in the same disc 'cause of the possibillity to create more than one vts ??
yes but only if your player does also. it sounds like powerdvd does not!
Having NTSC & PAL on the same dvd makes the DVD non compliant with the DVD specification. Many players which can play both TV standards however can handle them.
PowerDVD
By BobbyScot in forum Software PlayingReplies: 1Last Post: 28th Aug 2009, 13:38 -
Invalid Pointer error #80004003 PowerDVD - solved
By montrealer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2009, 09:49 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 12:18 -
PowerDVD v7.3 Ultra: "Fail to enable HDCP" error?
By ambushed19 in forum Software PlayingReplies: 2Last Post: 9th Feb 2009, 12:45 -
Powerdvd error 8902003 : DVD damaged
By Puneet in forum Software PlayingReplies: 3Last Post: 15th Dec 2007, 05:18
