I've few mpegs which has a format of 352 X 240, 4:3 525 lines (NTSC) & 23.976 FPS. I want to convert it into format of 352 X 288, 4:3 625 lines (PAL) & 25 FPS. Kindly name the software or technique which encodes it without losing clarity and resolution. I've tried Tmpeg, but it did'nt give any good results.![]()
Put simply: VCD encoding loses lots of quality in the process. Since what you want to do (changing frame rate along with resizing) requires reencoding, there's not much to do - whatever you use, you'll lose quality, and pretty signinficant too. (As you have noticed):
Good(?) NTSC source -> low q NTSC VCD copy of good NTSC source -> low q PAL copy of low q NTSC copy of good(?) NTSC source.
Since you want to convert to PAL, and most PAL equipment happlily plays NTSC, I'd try to do a NTSC VCD from your original MPG (without reencoding - just author and burn with VCDEasy). Chances are pretty good that it will work.
/Mats
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 08:54 -
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 3rd May 2011, 23:34 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 04:52 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52
