Is this possible like it is with AVI files?
I have an NTSC TV capture in MPG format and I need to convert it to PAL. I'm looking for the method which will yield the least quality degradation. Do I have to re-encode?
Then you need to learn how to use Avisynth. There's filters available to transcode from 29.97 interlaced to 25 interlaced, or vice versa.
Are you sure you need to convert it to 25 though? the majority of PAL DVD players can transcode 29.97 to 25 on playback (in fact i have -never- seen one that can't!), and if that's not an option a lot of PAL TV's will play NTSC anyway.
I'm assuming the MPEG is destined for DVD or VCD, as if it's only being viewed on a computer it doesn't make a blind bit of difference what format it is -
I know my PS2 plays em (region free ntsc DVD) but outputs in B&W. -
i'm afraid i don't have a ps2, so can't answer your qeustion. It should be possible to tell your PS2 to output to PAL only though, have a flick through the menus.
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 13:04 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48
