Hardware:
Pentium 3 1.33ghz
512MB RAM
40GB HD
Pioneer 106 IDE inside external USB 2.0 enclosure (connected to USB 2.0 port on my laptop)
Problem:
I'm able to duplicated DVDs with DVD Xcopy Xpress all day using DVD-R media purchased from meritline. It is LEADDATA01 branded media. According to information/reviews on this media the pioneer 106 shoudl have no problems writing on these discs.
However, when i use Nero 6 to burn 3.5 GB worth of data to the same type of media, i get the message "Invalid block address" and "could not perform end of Disc-at-once".
This occurs at the end of the write session.
I also tested a DVD-RW @ 2.4x and it writes succesfully. I'm totally confused.
any ideas?
I had similar problems with Memorex media it would not burn on DVD X Copy express and also with Princo.
It appears that DVD burning is sensitive to the media.The burner being used in your case the pioneer and the program being used
I would suggest that you try different media and find one that suits the program and software that you are using.
TDK media burn well on my sony DRU 500 -
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 08:40 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:12 -
Windows Media Encoder Fails on 2nd pass
By golfer53 in forum DVD RippingReplies: 2Last Post: 20th Feb 2009, 10:36 -
CD Copy with Nero Fails after a few burns
By kadzbiz in forum MediaReplies: 7Last Post: 5th Feb 2008, 19:46
