Hey,
Does anyone know where the option to selection the field order is in Cinema craft encoder 2.67 ? (i am using 2.67.00.11 but maybe they are other versions are similar)
I know TMPGEnc clearly has this option but i want to give CCE another chance....
TIA
Wasn't that answered at the end of your other post "what is field order?" ?
I didn't check to see if it was correct, but the post gave a bunch of details. -
Here is part of a post from that thread. It seems to say 2.67 is called Offset Line.
Hey !
some info from me (author of AviScript), hoping can help:
The field order in CCE (version 2.66 and lower) is called: Upper field first [Section Video]
The field order in CCE (since version 2.67) is called: Offset Line [Section Video] !!
set
Offset Line to 0 !
that's the same as Deselect Upper field first.
One Tip to Interlace:
To deinterlace a interlaced video (most after TV capture) use one of the Deinterlace filter in AviScript. But: If you want to play on television instead of a computer monitor, so don't change the original and don't deinterlace the video to get the best results !.
In CCE: If you encode an interlaced video, so deselect the option [Progressive frame] flag. Important: if your DVD standalone player produces a jearky video, so click in CCE to the button [Video...] to get the Encode Setting Window, deselect [Upper field first] (CCE 2.66 or lower) or change [Offset line to 0] (CCE 2.67).
=> hoping this can help you. I had the same problems before (jearky videos), now I don't deinterlace the videos in AviScript, set Offset Line to 0 and get a very good quality on my DVD standalone player / television.
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 09:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 16:11 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
