When I ran SVCD2DVD I set to "pick" only certain mpgs, but decided to move the ones I did want to a specific folder... when I went to the folder I moved them to, they were in the following format:
XXXXX - S0xE0x - XXXXX title.mpg
When I started SCVD2DVD using the mpgs I moved to a specific folder they now have been RENAMED to:
XXXXX _ S0xE0x _ XXXXX title.mpg
I doubt this is me... maybe something in the program??? I now have 200+ mpgs renamed with the "-" being replaced with an "_"
I even THOUGHT it was me and went and RENAMED all the mpgs I wanted converted\authored to the way they were, but lo and behold the underscores ARE BACK![]()
So to all, is this me or is anybody else seeing this???????
Thanks!
All filenames/folders which have a hypen are renamed to have an underscore. This is because one of the external programs falls over with files/folders containing hypens.
So from your reply I guess that this is not under your control.....
As much as I appreciate all the work you've done and the response time to my questions.... I would have like to have been aware of this so I could have copied\moved the files I wanted to work with... After looking at my folders I now have an excess of 500+ files that now have underscores....
All in all I think your program(s) is one of the best I've used! -
Just use a program called rename to change back the _ to - and i suggest you use a working directory for the source you want to run through svcd2dvd.
Greatings,
Yf -
if you want i can write you a 3 line program to change them back....
Guest
That would be most appreciated!
For the record though - this issue will always be part of the process as it is something out of your control correct? Has anybody else had issue with this as I have been following the forum since getting your program and have not seen any posting(s) reporting this....
For sheer response to my questions\comments - you rock! -
DOH! Guest post was me not logged in....
Appreciate the 3 liner and also Yf's response ( I do have a "renamer" but looking for it might be more than it's worth)
Anyway if you could write that 3 liner I'd be most appreciative....
And now I know to work from "working" directories..... -
http://www.svcd2dvdmpg.com/svcd2dvdmpg/renamer.zip
unzip to a folder & run the exe.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Something weird is happening here...
By montreal in forum ComputerReplies: 4Last Post: 21st Dec 2011, 16:23 -
FLV to WHATEVER NOT HAPPENING ANYMORE (MAIN@L3.0)
By Telomostro in forum Video ConversionReplies: 0Last Post: 6th Jun 2009, 16:58 -
.MOV to FLV not happening
By makman in forum ffmpegX general discussionReplies: 4Last Post: 21st Jul 2008, 16:48 -
Weird stuff happening. Help
By tim_ver in forum Newbie / General discussionsReplies: 14Last Post: 18th Oct 2007, 18:53 -
Traffic shaping on YouTube - is it happening elsewhere?
By Midzuki in forum Off topicReplies: 2Last Post: 20th Aug 2007, 19:03
