I have two movies I have processed using dvd Shrink How do I put them
on ! DVD-r I have the following tools DVDDecypter,DVDShrink,DVDXCOPY,INfo edit 95,DVDFAB HELP!!!!
I use nero to burn . do I have to rename all the files for the second movie? put them in separate folders? what is the procedure...
Results 1 to 13 of 13
Use the newest beta of DVD Shrink. That would be the easiest way to do it. Try a search next time, this question has been asked quite often.
I made a very rough guide that might be of help:
http://www.dvdshrink.info/re-author-v3beta5.php
I didn't bother to make a "proper" one as DVD Shrink interface will probably change in the final release.
Thank,but that is from disk I want to do it from Files on the hard drive aka IFO,BUP and VOBs
Darr1960, as stated in my rough guide, the principle is exactly the same.
Instead of clicking "Open Disk", choose "Open Files" and select the "VIDEO_TS.IFO" from the folder containing the ripped DVD.
Ok I got that how do you put more than one movie,when I open another files it replaces the one I already had..I want ot put two titiles on 1 DVD-R
It replaces the one you already had in the first window,
but you should have already dragged it to the second one so it doesn't matter. -
I still don't understand when I open files and then click re-author
it won't let me drap in another title it just replaces the one I hand there..
The re-authour is not working on my version of 3.0 Beta 5 I am trying to do it under version 2.3 help -
Sorry, Darr1960, I can't explain it any better than I've already had.
Ok, I finally figured it out you never said I had to open up another DVD shrink window and drag it to the re-author pane..Anyway thanks for all you help...
"Anyway thanks for all you help"
You're welcome.
"...you never said I had to open up another DVD shrink window..."
Because you don't have to.
Drag titles to the "New DVD" in the re-author window.
Open disks or files in the first one.
"ddlooping, you have the patience of a saint
I'm not sure about that, but thanks anyway.
"(and I love your software!)"
Thanks for the compliment, but I'm not DVD Shrink author.
dvdshrink is.
I'm just trying to help both him and his software users.
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 07:58 -
Problem with audio in file processed by GOTSENT
By Bavafan in forum AudioReplies: 3Last Post: 10th Sep 2010, 14:20 -
do my AVI files need to be "pre-processed" before creating DVD?
By EtherJones in forum Video ConversionReplies: 3Last Post: 11th Jun 2010, 01:46 -
DVD Shrink and putting 2 DVD onto 1 DVD
By articaine in forum DVD RippingReplies: 10Last Post: 28th Apr 2009, 13:20 -
Better to save processed vid to a different h/d than original file?
By brassplyer in forum EditingReplies: 4Last Post: 6th Jan 2009, 05:07
