im making vcd - dvd
i patch the vcds with svcd2dvdmpg, then i load the files into dvdlab, but once i burn the disk and everything, the video on my tv is fucked.
the video is crunched up using 1/2 of the monitor, the other half is black
anyone know how 2 fix this?
basically, all u r doing is patching ur vcd, ur r not actually creating a compliant dvd and ur player knows this, thats why u r seeing only half the screen, there r only a small amount of players, that would be able to play the file in it's full size.
u wil have to re-encode the video stream to 'full or half d1'.
Bless,
ukRevRend -
it shouldnt matter
when i use tmpenc dvd author it works ok, ahh, but i didnt patch the video file, ill try it and see if i get the same results
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
