I understand that it is possible to rip a PAL DVD and get the video file from it, however, what if I had a DVD image in PAL, is there any way to directly convert PAL to NTSC, any format, ISO, BIN, GI anything? No idea if this is possible.
you'd either have to burn the image to a disc and then rip as per usual, or mount the image as a virtual drive. a quick google search will tell you how to do that.
I hate to bump this, but Im wondering, so once I have the DVD mounted or whatever, how can i rip it into NTSC?
It is not that easy.
You have to re-encode it into NTSC using a MPEG-2 DVD compliant encoder such as TMPGEnc or CCE or MainConcepts etc.
Check out these two links for more info:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=
Good Luck
- John "FulciLives" Coleman
P.S.
The best way to start is to RIP the PAL movie with DVD Decrypter in FILE MODE default selects just the movie (not the extras). Then run that through DVD2AVI to get your AC-3 audio file(s) and your D2V file."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by Phluxed
Forget about it.
P.S.
You could keep the extras but each one would have to be encoded as seperate clips and then you could make your own new menu to select the movie or the extra feature clip you want."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
