U have an ac3 file with 2ch stereo when u look at it in virtualdub. Some say "yes" but most say "No" U can't get 5chDolby Digital from that source using programs like Besweet and HeadAc3...![]()
I do not believe that it is possible. You can get surround sound, but not digital surround sound. My mind is kinda blank right now and this is as good as I can explain it right now.
If the 2 channel sound is encoded with Dolby Surround then you can decode a rear channel and a centre channel. From this you can use the rear channel for both rear speakers, the centre for the centre, and clip the audio on all channels below 150hz and use this for the LFE channel.
All technically possible, but entirely pointless. instead just play back the stereo file, and set your surround amp to Pro Logic or Pro Logic II mode. This will do exactly the same thing.
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 17:58 -
AC3 (5.1 or 2ch) to 2ch mp3
By shun in forum AudioReplies: 4Last Post: 11th Nov 2008, 08:50 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
