Hi all,
I've tried to wade through all the guides but am having problems with my exact scenario.
I downloaded some PAL MPEGS some Glastonbury performances. The video is letterboxed.
I burned the MPEGS to DVD using TMPG DVD Authoring. They looked and sounded great so I wiped the source MPEGS off my HD. I then found out my standalone player doesn't support PAL.
I used DVD decrypter to extract the VOBs from my discs, but am having a devil of a time converting those VOBs to NTSC while keeping the same aspect ratio. TMPG wants to fill the screen or create a narrower image.
The stats on the VOB (I changed the .VOB suffix to .MPG so that TMPG would even open it) are: 720 x 576, 25.0 per sec.
Any suggestions on creating nice wide-screen, letterboxed NTSC chapters?
Thanks in advance!
Well NTSC will not support 720X576 so you'll have to re-encode to 720X480.
As for the frame rate issue, you can either slow the material down 4% to 23.976fps as NTSC Film, or use an AVIsynth script to perform a nice 25->29.97 FPS conversion.
When will the rest of the world learn? multi system is the way to go!
Facebook video scaling/aspect ratio issue
By 0344990 in forum Newbie / General discussionsReplies: 5Last Post: 17th Feb 2010, 13:54 -
Aspect ratio issue
By Browncoat in forum Newbie / General discussionsReplies: 14Last Post: 15th Nov 2009, 21:55 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 17:16 -
Aspect ratio issue with New LG L226WTG-BF monitor(s)
By JeffD in forum ComputerReplies: 4Last Post: 21st Aug 2007, 22:35
