  1. My TMPEGENC will not read mpeg layer 3 audio within my source avi file, and if i demux the audio then encode the audio sync is way off. Is there any way Tmpeg enc can read mpeg layer 3 audio files with some sort of plugin installed? Thanks.
    Apr 2003
    my computer, where else?
    don't have that problem with tmpgenc. what version are you running? also, open your source file in gspot and post the audio and video info so we can help.
    I said I'll be done in a minute. I meant a Microsoft minute.
  3. heres the info on the audio:
    055(MP3) Id'd as MPEG-1 Layer 3
    150 kb/s (75/ch, stereo)VBR
    FS: 48000 Hz
    Aug 2002
    Pittsburgh, PA, USA
    Have you tried saving to wave with VDub and the using the wave file as your audio input ? VBR can cause that problem.
  5. i dont want to demux the audio. i just want tmpeg enc (or any other encoder) to read it from the source file.
    Aug 2002
    Pittsburgh, PA, USA
    Well, I know what you want, but I've never had much luck with VBR MP3 files and Tmpgenc without changing to .wav first. There is no "MP3 plug-in" for Tmpgenc, so you may have to read around to see if someone has a better idea. Have you tried the Tmpgenc forums @ the website ?
  7. I also used to have nothing but problems with any VBR audio in TMPGEnc. But the latest version solved pretty much every audio problem I had. Try the latest version first. I am now able to use DivX and Xvid source files with VBR mp3 files with no problems, the DVD compliant output mpeg has perfectly sync'd audio.
