    Mar 2002
    Ireland, Republic of
    I know the answer seems obvious, but does the quality of rendered video (DV-AVI) vary depending on the software you use? Will video rendered in Premiere or Vegas be the same quality as rendering done in Movie Maker?
    I like to use Movie Maker for small projects because its so simple to use, but I want to make sure I'm getting the best quality. Also does anyone know why Movie Maker 2 takes so long to render? This is also what puts me off using it.
    Thanks for your help.
    Mar 2003
    Uranus
    You computer is the speed problem. Most people
    use 1500 MHz or more. That makes the difference
    between 6 hours and 3 hours.
    Always encode overnight and you won't care
    Also, most of the serious video nuts use TMPGenc or CCE
    for encoding.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    No way, they won't be the same. Having said that, I don't know which is better. Try a few clips and compare for yourself.
