I have a 65" 16x9 ratio TV, but several DVD's that I own have a very slim letterbox, while others that I have will fill up the entire screen perfectly. My TV can change the view format for some with a letterbox by simply expanding the letterbox to fill the screen. Other DVD's have such a slim letterbox that even when expanded barely take up the space that a normal letterbox would.
Is there a reason for this? Also, can I copy these DVD's and reformat them to take up the full screen? It's kind of stupid for these DVD's to have such a slim format, I just can't understand how anyone could even watch them on a normal sized TV, they'd be so small.
Thanks!
The reason that some have very slim black bars is because they most likly have a ratio of 2:35 or 2:40.Should say on the back of the dvd case.
The ones that file the tv have a ratio of 1:85,or sometimes a bit smaller i.e 1:77.
They are still widescreen movies just with a different ratio.Big 3 User.....
PAL User.......
letterbox problem on burned dvd ...
By perik in forum MacReplies: 5Last Post: 8th Jun 2010, 02:01 -
After burning, the DVD changed to CD
By coody in forum DVD RippingReplies: 2Last Post: 29th Sep 2009, 12:41 -
After burning, DVD disc was changed to CD
By coody in forum ComputerReplies: 0Last Post: 22nd Sep 2009, 21:16 -
DVD won't display as letterbox in standard TV 4:3
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Jun 2008, 11:48 -
Missing subs, size & font can't be changed
By Jacke in forum ffmpegX general discussionReplies: 2Last Post: 17th Aug 2007, 12:04
