Hello,
How can you tell a balnk DVD which is sold under a name (for example Ritek) is branded or unbranded. If the branded Ritek should have the logo on the DVD and factory seal, how can we tell a inkjet printable DVD is Branded or unbranded? As you know some on line sellers ship the media in the name of (for example Ritek) but the product could be anything with Ritek ID number (i.e. G04). If my question is confusing, please just explain how do you define unbranded media specially when it comes to inkjet printable discs. Thanks.
Over 45 hits and no reply. lol. maybe I should revise my post. here it is:
If I buy a 4x Ritek DVD-R with the manufacturer ID Ritek G04, Does it matter what name has been printed on the disc (i.e. RIDATA, or Y's Power, etc.) or where it was made. Do all discs with the manufacturer ID Ritek G04 have the same quality/compatibility? Thanks for your input. -
You can use software named DVDInfo to check the disk if it's ritek or not and also the max speed
I think the number one rule when considering blank DVD media is never assume anything. Just because it says on thing on the box or disc does not mean two discs that look the same will be the same 'inside'.
Even two different batches of blank DVDs can burn differently in terms of quality. Unfortunately there is no standard and that is why there is no way to know for sure. The best way is to test a batch you are interested in before committing to a large purchase. Even Verbatim (which used to be considered a really good buy) has been known to use substandard knockoffs on occasion.
Nothing is certain where blank DVD media is concerned.
Regards,
Savant
Successfully Burned 4.99 GB onto ASDA Branded DVD+R Disc
By Mixtrixx in forum MediaReplies: 5Last Post: 29th Aug 2009, 10:10 -
Is it still possible to get MIJ "Branded" tayo yudens DVD+Rs at B
By ty1er in forum MediaReplies: 2Last Post: 28th May 2009, 21:30 -
Polaroid branded LCD TVs with tuners- anybody have comments?
By ahhaa in forum DVB / IPTVReplies: 7Last Post: 1st Nov 2007, 15:45 -
Non Fake Branded TY Media In Australia
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 26th Jul 2007, 00:45 -
What's generally cheaper: To build a PC yourself or buy a Branded one ???
By navi310 in forum ComputerReplies: 48Last Post: 11th Jun 2007, 10:34
