Hi,
i've just try to use a little bit this application and i have a question.
I want to make a dvd, i can play on my DVD player, with some of my TV shows i have on my computer.
When i try to import assets ( these EP), Encore always answer me two type of message:
-when i choose a PAL project "This project requieres MPEG video to be encoded as PAL"
-when i choose a NTSC project " this file is not suported"
Here are the informations of the file i try to import:
704 x 480, 25fps, video/mpeg
What i have to do, to import this files?
Thanks for your answer
Benjamin
I guess some of us have the "iligal" software...i am facing the same problem..
u have th 144Mo version?
maybe we don't have all the modules, we need to import this type of file -
Hmm seems weird, but unfortuantely I cannot help you as I dunno nothing about Adobe DVD *yet*, but I speak for everyone when I say... Let the program open to the media and let us learn how to use it before we post answers, I dont think we can expect professional answers when this came out like 2 weeks ago
Give it time
With the video you have, you might get this kind of answer in lots of autoring apps: 704x480 (expect NTSC) with 25 fps (expect PAL) will confuse the hell out of it.
you're probably going to have to re-encode to a correct format 1st.
For full D1 resolution, make sure it's:
704x480 or 720x480 @ 29.97fps for NTSC
-or-
704x576 or 720x576 @ 25fps for PAL
HTH,
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
