Hello
As I understand there is no support for subtitles in DVD-Lab. Is it possible to do just the meny-part in DVD-Lab and then use that meny with finished vobfiles that are authored in IFO-Edit which support subs and multiple audio.
Meaning correct/edit the meny ifo-file using IFO-Edit to get it connected to finnished vobfiles??
Yes you can do this (I haven't but a few guides have been posted outlining the process). Remember thou that you can not generate a menu that would allow to select the subtitle track or other audio streams (you'll have to do it manually on the remote, or set the subs to auto play).
I just did a guide about it:
https://www.videohelp.com/forum/viewtopic.php?p=655210
[]'s
VMesquita
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 09:14 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
