Hello,
I've been trying to convert downloaded DivX/avi movies to VCD/mpeg format with TMPGEnc using the standard VCD settings and always choosing the Mpeg file format (Ntsc film etc.) according to the source file in order to avoid framerate problems.
Encoded files play fine on my pc but I always face the following problems when playing the burned (Nero, 4x) VCDs on my DVD player (which is VCD/SVCD compatible).
Problem1: picture is jerky and "jumps" constantly every few seconds throughout the whole VCD, audio seems fine
Problem2: picture freezes now and then and a couple of seconds are skipped before VCD plays on, audio plays normal.
I've already wasted lots of CD-Rs, trying different settings both in the burning and conversion process but nothing seems to help, so it would be really great if someone couled help me with this problem....
Nick
I get this exact same problem, nothing seems to help. Im trying to use CCE instead but havent quite got the hang of it. If u do eventually get this working, lemme know how u did it :P
Sorry you can't get back the 4 seconds wasted reading this. -
I have the same problem as you do with some AVI files. Try using VCD EASY after you encode with TMPGE. I use TMPGE to encode the AVI FILES then use VCD EASY to burn to VCD. VCD EASY is now a shareware program that you have to pay for. Their free version has limitations. I was lucky to keep their old versions that still work for me.
I used Nero tonight to burn a cue file and then made a copy of it on vhs tape. The vhs tape was blocky and crappy. I realized I used the cue file I burned on Nero and not the one I did with VCD EASY. I redid the vhs tape using the VCD EASY one and it was fine with no blocky pixels.
OWNER OF 2 APEX 1500's REGION FREE AND MACROVISION FREE
LENOXX 2003 DVD REGION FREE AND MACROVISION FREE
RCA DRN220 REGION FREE
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 17:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22
