The original .mov file is perfect but when I convert it to a DVD and play it, the audio is way ahead of the picture.
Have you used the same framerate as the source to encode it?
If no, try to do that. Also try to disable the 3:2 pulldown checkbox.
If the problem is not solved, I could do some tests if you post me a link to download a clip from your source, together with the settings you used to encode it.
I tried that and came up with this: (pasted below)
also, the MOV file is 23.49 GB. When I click on "info" here is the info I get: Fourcc: cvd Codec: 'DV/DVCPRO - NTSC' [v} filefmt:7 fourcc:0x20637664 size: 720x480 fps: 29.97 ftime:=0.0334 audiocodec: framecopy (format=0 chans=2 rate=48000 bits=16 bps=914502 sample=54464
Last login: Sat Aug 23 11:29:08 on ttyp2
pbpaste | sh
Welcome to Darwin!
[My-Computer:~] jj% pbpaste | sh
Encoding started on Sun Aug 24 00:14:09 EDT 2003
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 665804328 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/EZQuest/france main/france.mp2"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Volumes/EZQuest/france main/france.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/EZQuest/france main/france.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting DVD output profile (INCOMEPLETE!!!!)
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/EZQuest/france main/france.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/EZQuest/france main/france.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4302800
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] STREAM c0 completed @ 144487.
INFO: [mplex] Scanned to end AU 103901
INFO: [mplex] STREAM e0 completed @ 103901.
INFO: [mplex] Multiplex completion at SCR=389945782.
INFO: [mplex] Video e0: buf= 54919 frame=103901 sector=01029509
INFO: [mplex] Audio c0: buf= 4096 frame=144487 sector=00048068
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 259709806 bytes
INFO: [mplex] Sequence headers: 7012
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 103902
INFO: [mplex] No. Groups : 7012
INFO: [mplex] No. I Frames : 7012 avg. size 32207 bytes
INFO: [mplex] No. P Frames : 27711 avg. size 22886 bytes
INFO: [mplex] No. B Frames : 69179 avg. size 17601 bytes
INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 3835600 bits/sec
INFO: [mplex] Peak bit-rate : 4276400 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 97095936 bytes.
INFO: [mplex] Syncwords : 144488
INFO: [mplex] Frames : 144488 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex]
INFO: [mplex] MUX STATUS: no under-runs detected.
STAT: Processing /Volumes/EZQuest/france main/france.mpg...
STAT: VOBUS: 7012, 2118MB
STAT: last time=4332.73 sec
INFO: Generating VTS with the following video attributes:
INFO: TV standard: NTSC
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio format: mp2
STAT: fixing VOBU at 2117MB (7008/7012, 99%)
tocgen running
scanning /Volumes/EZQuest/france main/france.DVD/VIDEO_TS/VTS_01_0.IFO
0.46% done, estimate finish Sun Aug 24 07:29:10 2003
0.92% done, estimate finish Sun Aug 24 07:30:58 2003
1.38% done, estimate finish Sun Aug 24 07:31:34 2003
1.84% done, estimate finish Sun Aug 24 07:31:52 2003
2.30% done, estimate finish Sun Aug 24 07:32:03 2003
2.77% done, estimate finish Sun Aug 24 07:31:34 2003
3.23% done, estimate finish Sun Aug 24 07:31:44 2003
3.69% done, estimate finish Sun Aug 24 07:31:52 2003
4.15% done, estimate finish Sun Aug 24 07:31:58 2003
4.61% done, estimate finish Sun Aug 24 07:32:03 2003
5.07% done, estimate finish Sun Aug 24 07:32:07 2003
5.53% done, estimate finish Sun Aug 24 07:32:10 2003
5.99% done, estimate finish Sun Aug 24 07:31:56 2003
6.45% done, estimate finish Sun Aug 24 07:32:00 2003
6.91% done, estimate finish Sun Aug 24 07:32:03 2003
7.37% done, estimate finish Sun Aug 24 07:32:06 2003
7.83% done, estimate finish Sun Aug 24 07:32:08 2003
8.30% done, estimate finish Sun Aug 24 07:32:10 2003
8.76% done, estimate finish Sun Aug 24 07:32:01 2003
9.22% done, estimate finish Sun Aug 24 07:32:03 2003
9.68% done, estimate finish Sun Aug 24 07:32:05 2003
10.14% done, estimate finish Sun Aug 24 07:32:07 2003
10.60% done, estimate finish Sun Aug 24 07:32:09 2003
11.06% done, estimate finish Sun Aug 24 07:32:10 2003
11.52% done, estimate finish Sun Aug 24 07:32:12 2003
11.98% done, estimate finish Sun Aug 24 07:32:13 2003
12.44% done, estimate finish Sun Aug 24 07:32:06 2003
12.90% done, estimate finish Sun Aug 24 07:32:08 2003
13.36% done, estimate finish Sun Aug 24 07:32:09 2003
13.83% done, estimate finish Sun Aug 24 07:32:10 2003
14.29% done, estimate finish Sun Aug 24 07:32:11 2003
14.75% done, estimate finish Sun Aug 24 07:32:13 2003
15.21% done, estimate finish Sun Aug 24 07:32:07 2003
15.67% done, estimate finish Sun Aug 24 07:32:08 2003
16.13% done, estimate finish Sun Aug 24 07:32:09 2003
16.59% done, estimate finish Sun Aug 24 07:32:10 2003
17.05% done, estimate finish Sun Aug 24 07:32:11 2003
17.51% done, estimate finish Sun Aug 24 07:32:12 2003
17.97% done, estimate finish Sun Aug 24 07:32:13 2003
18.43% done, estimate finish Sun Aug 24 07:32:09 2003
18.89% done, estimate finish Sun Aug 24 07:32:09 2003
19.36% done, estimate finish Sun Aug 24 07:32:10 2003
19.82% done, estimate finish Sun Aug 24 07:32:11 2003
20.28% done, estimate finish Sun Aug 24 07:32:12 2003
20.74% done, estimate finish Sun Aug 24 07:32:13 2003
21.20% done, estimate finish Sun Aug 24 07:32:13 2003
21.66% done, estimate finish Sun Aug 24 07:32:10 2003
22.12% done, estimate finish Sun Aug 24 07:32:10 2003
22.58% done, estimate finish Sun Aug 24 07:32:11 2003
23.04% done, estimate finish Sun Aug 24 07:32:12 2003
23.50% done, estimate finish Sun Aug 24 07:32:12 2003
23.96% done, estimate finish Sun Aug 24 07:32:13 2003
24.42% done, estimate finish Sun Aug 24 07:32:14 2003
24.89% done, estimate finish Sun Aug 24 07:32:10 2003
25.35% done, estimate finish Sun Aug 24 07:32:11 2003
25.81% done, estimate finish Sun Aug 24 07:32:12 2003
26.27% done, estimate finish Sun Aug 24 07:32:12 2003
26.73% done, estimate finish Sun Aug 24 07:32:13 2003
27.19% done, estimate finish Sun Aug 24 07:32:13 2003
27.65% done, estimate finish Sun Aug 24 07:32:14 2003
28.11% done, estimate finish Sun Aug 24 07:32:11 2003
28.57% done, estimate finish Sun Aug 24 07:32:11 2003
29.03% done, estimate finish Sun Aug 24 07:32:12 2003
29.49% done, estimate finish Sun Aug 24 07:32:13 2003
29.96% done, estimate finish Sun Aug 24 07:32:13 2003
30.42% done, estimate finish Sun Aug 24 07:32:14 2003
30.88% done, estimate finish Sun Aug 24 07:32:11 2003
31.34% done, estimate finish Sun Aug 24 07:32:11 2003
31.80% done, estimate finish Sun Aug 24 07:32:12 2003
32.26% done, estimate finish Sun Aug 24 07:32:12 2003
32.72% done, estimate finish Sun Aug 24 07:32:13 2003
33.18% done, estimate finish Sun Aug 24 07:32:13 2003
33.64% done, estimate finish Sun Aug 24 07:32:14 2003
34.10% done, estimate finish Sun Aug 24 07:32:11 2003
34.56% done, estimate finish Sun Aug 24 07:32:12 2003
35.03% done, estimate finish Sun Aug 24 07:32:12 2003
35.49% done, estimate finish Sun Aug 24 07:32:13 2003
35.95% done, estimate finish Sun Aug 24 07:32:13 2003
36.41% done, estimate finish Sun Aug 24 07:32:14 2003
36.87% done, estimate finish Sun Aug 24 07:32:14 2003
37.33% done, estimate finish Sun Aug 24 07:32:12 2003
37.79% done, estimate finish Sun Aug 24 07:32:12 2003
38.25% done, estimate finish Sun Aug 24 07:32:13 2003
38.71% done, estimate finish Sun Aug 24 07:32:13 2003
39.17% done, estimate finish Sun Aug 24 07:32:13 2003
39.63% done, estimate finish Sun Aug 24 07:32:14 2003
40.09% done, estimate finish Sun Aug 24 07:32:12 2003
40.56% done, estimate finish Sun Aug 24 07:32:12 2003
41.02% done, estimate finish Sun Aug 24 07:32:12 2003
41.48% done, estimate finish Sun Aug 24 07:32:13 2003
41.94% done, estimate finish Sun Aug 24 07:32:13 2003
42.40% done, estimate finish Sun Aug 24 07:32:13 2003
42.86% done, estimate finish Sun Aug 24 07:32:14 2003
43.32% done, estimate finish Sun Aug 24 07:32:12 2003
43.78% done, estimate finish Sun Aug 24 07:32:12 2003
44.24% done, estimate finish Sun Aug 24 07:32:13 2003
44.70% done, estimate finish Sun Aug 24 07:32:13 2003
45.16% done, estimate finish Sun Aug 24 07:32:13 2003
45.62% done, estimate finish Sun Aug 24 07:32:14 2003
46.09% done, estimate finish Sun Aug 24 07:32:14 2003
46.55% done, estimate finish Sun Aug 24 07:32:12 2003
47.01% done, estimate finish Sun Aug 24 07:32:12 2003
47.47% done, estimate finish Sun Aug 24 07:32:13 2003
47.93% done, estimate finish Sun Aug 24 07:32:13 2003
48.39% done, estimate finish Sun Aug 24 07:32:13 2003
48.85% done, estimate finish Sun Aug 24 07:32:14 2003
49.31% done, estimate finish Sun Aug 24 07:32:14 2003
49.77% done, estimate finish Sun Aug 24 07:32:12 2003
50.23% done, estimate finish Sun Aug 24 07:32:13 2003
50.69% done, estimate finish Sun Aug 24 07:32:13 2003
51.15% done, estimate finish Sun Aug 24 07:32:13 2003
51.62% done, estimate finish Sun Aug 24 07:32:14 2003
52.08% done, estimate finish Sun Aug 24 07:32:14 2003
52.54% done, estimate finish Sun Aug 24 07:32:14 2003
53.00% done, estimate finish Sun Aug 24 07:32:13 2003
53.46% done, estimate finish Sun Aug 24 07:32:13 2003
53.92% done, estimate finish Sun Aug 24 07:32:13 2003
54.38% done, estimate finish Sun Aug 24 07:32:13 2003
54.84% done, estimate finish Sun Aug 24 07:32:14 2003
55.30% done, estimate finish Sun Aug 24 07:32:14 2003
55.76% done, estimate finish Sun Aug 24 07:32:12 2003
56.22% done, estimate finish Sun Aug 24 07:32:13 2003
56.68% done, estimate finish Sun Aug 24 07:32:13 2003
57.15% done, estimate finish Sun Aug 24 07:32:13 2003
57.61% done, estimate finish Sun Aug 24 07:32:14 2003
58.07% done, estimate finish Sun Aug 24 07:32:14 2003
58.53% done, estimate finish Sun Aug 24 07:32:14 2003
58.99% done, estimate finish Sun Aug 24 07:32:13 2003
59.45% done, estimate finish Sun Aug 24 07:32:13 2003
59.91% done, estimate finish Sun Aug 24 07:32:13 2003
60.37% done, estimate finish Sun Aug 24 07:32:13 2003
60.83% done, estimate finish Sun Aug 24 07:32:14 2003
61.29% done, estimate finish Sun Aug 24 07:32:14 2003
61.75% done, estimate finish Sun Aug 24 07:32:14 2003
62.21% done, estimate finish Sun Aug 24 07:32:13 2003
62.68% done, estimate finish Sun Aug 24 07:32:13 2003
63.14% done, estimate finish Sun Aug 24 07:32:13 2003
63.60% done, estimate finish Sun Aug 24 07:32:13 2003
64.06% done, estimate finish Sun Aug 24 07:32:14 2003
64.52% done, estimate finish Sun Aug 24 07:32:14 2003
64.98% done, estimate finish Sun Aug 24 07:32:14 2003
65.44% done, estimate finish Sun Aug 24 07:32:13 2003
65.90% done, estimate finish Sun Aug 24 07:32:13 2003
66.36% done, estimate finish Sun Aug 24 07:32:13 2003
66.82% done, estimate finish Sun Aug 24 07:32:14 2003
67.28% done, estimate finish Sun Aug 24 07:32:14 2003
67.74% done, estimate finish Sun Aug 24 07:32:14 2003
68.21% done, estimate finish Sun Aug 24 07:32:14 2003
68.67% done, estimate finish Sun Aug 24 07:32:14 2003
69.13% done, estimate finish Sun Aug 24 07:32:13 2003
69.59% done, estimate finish Sun Aug 24 07:32:13 2003
70.05% done, estimate finish Sun Aug 24 07:32:14 2003
70.51% done, estimate finish Sun Aug 24 07:32:14 2003
70.97% done, estimate finish Sun Aug 24 07:32:14 2003
71.43% done, estimate finish Sun Aug 24 07:32:14 2003
71.89% done, estimate finish Sun Aug 24 07:32:13 2003
72.35% done, estimate finish Sun Aug 24 07:32:13 2003
72.81% done, estimate finish Sun Aug 24 07:32:14 2003
73.27% done, estimate finish Sun Aug 24 07:32:14 2003
73.74% done, estimate finish Sun Aug 24 07:32:14 2003
74.20% done, estimate finish Sun Aug 24 07:32:14 2003
74.66% done, estimate finish Sun Aug 24 07:32:14 2003
75.12% done, estimate finish Sun Aug 24 07:32:13 2003
75.58% done, estimate finish Sun Aug 24 07:32:13 2003
76.04% done, estimate finish Sun Aug 24 07:32:14 2003
76.50% done, estimate finish Sun Aug 24 07:32:14 2003
76.96% done, estimate finish Sun Aug 24 07:32:14 2003
77.42% done, estimate finish Sun Aug 24 07:32:14 2003
77.88% done, estimate finish Sun Aug 24 07:32:14 2003
78.34% done, estimate finish Sun Aug 24 07:32:13 2003
78.80% done, estimate finish Sun Aug 24 07:32:13 2003
79.27% done, estimate finish Sun Aug 24 07:32:14 2003
79.73% done, estimate finish Sun Aug 24 07:32:14 2003
80.19% done, estimate finish Sun Aug 24 07:32:14 2003
80.65% done, estimate finish Sun Aug 24 07:32:14 2003
81.11% done, estimate finish Sun Aug 24 07:32:14 2003
81.57% done, estimate finish Sun Aug 24 07:32:13 2003
82.03% done, estimate finish Sun Aug 24 07:32:14 2003
82.49% done, estimate finish Sun Aug 24 07:32:14 2003
82.95% done, estimate finish Sun Aug 24 07:32:14 2003
83.41% done, estimate finish Sun Aug 24 07:32:14 2003
83.87% done, estimate finish Sun Aug 24 07:32:13 2003
84.33% done, estimate finish Sun Aug 24 07:32:13 2003
84.80% done, estimate finish Sun Aug 24 07:32:13 2003
85.26% done, estimate finish Sun Aug 24 07:32:14 2003
85.72% done, estimate finish Sun Aug 24 07:32:14 2003
86.18% done, estimate finish Sun Aug 24 07:32:14 2003
86.64% done, estimate finish Sun Aug 24 07:32:14 2003
87.10% done, estimate finish Sun Aug 24 07:32:13 2003
87.56% done, estimate finish Sun Aug 24 07:32:13 2003
88.02% done, estimate finish Sun Aug 24 07:32:14 2003
88.48% done, estimate finish Sun Aug 24 07:32:14 2003
88.94% done, estimate finish Sun Aug 24 07:32:14 2003
89.40% done, estimate finish Sun Aug 24 07:32:13 2003
89.87% done, estimate finish Sun Aug 24 07:32:13 2003
90.33% done, estimate finish Sun Aug 24 07:32:13 2003
90.79% done, estimate finish Sun Aug 24 07:32:13 2003
91.25% done, estimate finish Sun Aug 24 07:32:14 2003
91.71% done, estimate finish Sun Aug 24 07:32:14 2003
92.17% done, estimate finish Sun Aug 24 07:32:14 2003
92.63% done, estimate finish Sun Aug 24 07:32:13 2003
93.09% done, estimate finish Sun Aug 24 07:32:13 2003
93.55% done, estimate finish Sun Aug 24 07:32:13 2003
94.01% done, estimate finish Sun Aug 24 07:32:14 2003
94.47% done, estimate finish Sun Aug 24 07:32:14 2003
94.94% done, estimate finish Sun Aug 24 07:32:13 2003
95.40% done, estimate finish Sun Aug 24 07:32:13 2003
95.86% done, estimate finish Sun Aug 24 07:32:13 2003
96.32% done, estimate finish Sun Aug 24 07:32:13 2003
96.78% done, estimate finish Sun Aug 24 07:32:13 2003
97.24% done, estimate finish Sun Aug 24 07:32:14 2003
97.70% done, estimate finish Sun Aug 24 07:32:14 2003
98.16% done, estimate finish Sun Aug 24 07:32:13 2003
98.62% done, estimate finish Sun Aug 24 07:32:13 2003
99.08% done, estimate finish Sun Aug 24 07:32:13 2003
99.54% done, estimate finish Sun Aug 24 07:32:13 2003
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4096
Path table size(bytes): 42
Max brk space used 0
1084960 extents written (2119 Mb)
Encoding completed on Sun Aug 24 07:32:14 EDT 2003
[My-Computer:~]jj%
The only thing I got was an mpv file with no audio. Nothing else.
I'm not sure what went wrong last time, but I tried again and it worked much better. I still have some slight sync issues but I think it is a problem on my MOV file since they are not consistant throughout the movie. Not nearly as bad as before.
If anyone know an easy way to "re-sync" the movie at various places let me know!
thanks
Mov audio/video sync problem
By adabo in forum EditingReplies: 7Last Post: 28th Jun 2018, 12:09 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
bleeping MOV audio sync
By MALIGNITY in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2011, 08:42 -
.Mov Videos Out of Sync
By bguguen in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2009, 19:09 -
Out-of-sync MOV File
By xeroid in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2008, 15:41
