  1. hello,
    i doen a movie with thempg, and the file was about 1.5giga (2 cd's)
    but when i cut it with thempg program NEROburn didnt recognaized the files.
    how can i fix it, or do i need to use a difrent program ?
    (i cant split the file in the encoding of the movie becouse it has a sync problem)
    10x.
  2. if(thempg == tmpgenc)
    Then make sure when you load the mpeg to cut it, that you keep it as MPEG2 Super Video Disc and not MPEG2 System.
    else return(NO_CLUE)
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
    Jan 2003
    India
    If u mean TMPGEnc and are making VCDs-in the dialog box select MPEG1 Video CD if u are making compliant CDs.
    Apr 2002
    The State of Frustration
    Try and fix the synch problem with this guide. Then try to down your encoding.
    Hello.
  5. 10x guys, help was quick and good.
    i save the output as mpeg2 and thats why it didnt work.
    10x.
