    Jul 2003
    I am about to reencode my video to have it remuxed in Ifoedit. Are the following settings correct?
    source type...interlaced
    I, P, B...1, 5, 2 respectively
    output interval...1
    closed GOP...disabled
    Are there any other particular settings that I need to watch out for when I am reencoding? The first time I did this, there was no video at all on the finished DVD.
    Apr 2002
    The State of Frustration
    If you get an error message when opening like file unsupported or can not open or is not supported
    or you get an empty(black) video preview window
    or the video look wierd in the video preview window like green or purple or pink
    Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.
    Make sure you check this out as well.
    Hello.
