Hi all, im still a newbie at DVD Shrink and im made a few like 3 and so i have been having troubles with the dvd playback... one of the movies were skipping..... and then one of the movies sometimes stop in the middle after the warning screen had loaded. Is there anything i could do to fix the problem? Thanks in advance.
anyone? or please forgive me if i made this post too quickly, is there any topic with the same one i have anywhere in this forum.... if so please give me a link. Thanks in advance.
OK, DVD Shrink should work for you with the majority of DVDs. Occassionally you will tackle one that refuses to rip well. You should not be having any problems with playback. It might be something as simple as a media / player / burner program issue. DVD shrink only creates a set of decrypted files which are visual exactly the same as if when you open the disks contents using your Windows Explorer. The only diference is that they are now not protected against copying.
Assuming the movie was copied without any compression, it should be a bit for bit copy. I assume you have become familiar with the use of the"Author" mode. Here you open the 2nd window. Going back to the 1st window youo selet and open the main movie and drag the file over to the 2nd or AUTHOR window. There you will see the various Aduio files and such. Uncheck what youo do not want. I usually leav the 6 channel english and the english subs. If after doing so, I still have a file that exceeds the limit ( will show as RED ) I choose the compression I need to bring it all to green. If you already know how to do this I apologize.
After backinig up to a folder of your choice, I use NERO burn, the older version 5-5-10-50 works best for me. Use the Wizard and chooce DVD / New / Other format / DVD/Movie. The prog will create to folders - AUDIO_TS and VIDEO_TS. Must be all caps. Drag the files that shirnk created into and inside the VIDEO_TS folder that was created by NERO.
Click on burn and DO NOT USE your computer for anything during the burn. I would even disable any anti virus software during the burn. You do not want anything disrupting the write process. The disk will FINALIZE and then you ought to be able to play it on most machines.
After this long winded explanation, I would ask you if you have tried the movies you backed up on any other players and if you were getting the same playback problems. I have 7 DVD players at home ( hard to believe!! ) and I can get most of them to play all my movies that I back up. MOST of the time it is a media or player problem.
Hope this helps
Take careNo DVD can withstand the power of DVDShrink along with AnyDVD! -
Hey thanks for the reply and about the authoring, u taught me something new....i didnt know how to author before wit the dvd shrink. And about the media u mentioned.... which media do u use?
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
New Guy Here,will need help converting vhs and beta to dvd
By MrHawhn in forum Newbie / General discussionsReplies: 5Last Post: 3rd May 2011, 21:04 -
WDTV Live (BETA has DVD Navigation!)
By jg0001 in forum Media Center PC / MediaCentersReplies: 10Last Post: 18th Apr 2011, 22:42 -
DVDFab 4.0.2.0 Beta backup crashed Shrink - fixed(sort off)
By pchan in forum DVD RippingReplies: 1Last Post: 21st Dec 2007, 10:04 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
