Me again!
Now got audio after TMPG Encoding an .avi file to MPEG, but it's basically crap compared to the .avi audio track. Can anyone tell me either: a) how to prevent the distortion, or b) recommend a tool to fix the audio track?
Cheers.
honorarybrutha - is this what you mean?
GSpot video info:
The following codecs all claim to be capable of processing this format:
--> {DivXMPEG-4 Low-Motion}
{ffdshow MPEG-4 Video Decoder}
{DivX MPEG-4 DVD Video Decompressor }
DirectShow is apparently able to play the file as well (see "DirectShow Render", below),
GSpot audio info:
Audio Format:
Code: 0x2000
Vendor: Dolby Laboratories, Inc
--> {CyberLink Audio Decoder}
{Nero Digital Audio Decoder}
--> {AC3 from AVI XForm} --> {Nero Digital Audio Decoder}
DirectShow was also able to find a codec to render it - the sound for this media clip should work fine.
See the DirectShow Render details for more info. -
use VD to save it as a wav file, and feed that to tmpgenc
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
install Odio Dekoda. should fix your problem. then load the source file in tmpgenc for both the audio and video. shouldn't need to save a wav audio out with vdub. no problems with audio sync either this way.
http://www.moonlight.co.il/download/?dl=odiodekodaI said I'll be done in a minute. I meant a Microsoft minute.
Any help on restoring faulty mpeg files? Thanks.
By seymoria in forum RestorationReplies: 3Last Post: 12th Jun 2010, 09:59 -
faulty 'avi container' file
By dizzi in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2010, 00:18 -
faulty DVD-R will not finalize
By joecass in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Nov 2009, 18:51 -
Faulty tv?
By alintatoc in forum ComputerReplies: 7Last Post: 18th Apr 2009, 12:24 -
How do you determine if your transport stream is faulty?
By yoda313 in forum DVB / IPTVReplies: 20Last Post: 21st Jul 2008, 02:10
