I use Maestro to author. I was wondering if there is a way to have a menu consisting of 4 separate motion clips designating chapters. I know how to do just one big motion menu. But I want motion chapter indicators on a menu. Is this possible?
??? What are you actually trying to do? If you want a motion menu with several selectable buttons/clips, yes you can do that (eg. matrix). If you mean can you display four seperate MPGs on the screen at once, then no.
Remember that motion menus are nothing more than regular mpeg2 files with a subpicture to define the buttons. There are a lot of ways to make 'chapter motion menus': Chapitre, TSCV, AVISynth, Premeire, etc. -
Sorry for the vague description. I didn't know how to word it, but I think you kinda got it. I want a black bitmap. On it I wish to have a small
2 inch x 2 inch running video clip labeled chapter one. Next to that, have chapter 2-4 and so on, so there is several running clips to demonstrate the chapters. I don't much for different software applications so I figured I would ask what to use.
The best app for this job is Adobe After Effects, I've also heard good things about Vegas Video but have not tried it personally for this task.
Check out the following guide...
https://www.videohelp.com/forum/userguides/164477.php
Is this what your after? -
Alas, Maestro does not create assets for you. You must use something else.
Personally, I use the same general process out lined in that guide. Avisynth/Vdub gives you the most control.
However, DVD-Lab 1.3 looks like it will do thumbnail menus for you. You could use it to make the menu, the rip the mpg back out, and plop it into Maestro.
I reformat my hard drive every month so I can re-install the DVD-Lab demo.
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 16:17 -
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
2D Motion Video
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 24th Aug 2008, 16:54 -
Motion
By augiecrazy8 in forum MacReplies: 1Last Post: 12th May 2008, 01:18
