I know this has been covered numerous times, but I'm a little lost with this one.
Basically I have a DivX AVI coded at 25fps and 48000 MP3 128khz for audio that I am trying to convert and author to DVD.
In the past when I was making only VCD's, I would simply save the audio as a wav with Virtual Dub, load the avi for video in TMPGEnc and the wav file for audio, select 29.97 and presto! I would have a perfectly fine mpeg1 file that was perfectly in sync.
Now, when I try to follow the same steps for DVD using the NTSC DVD template included with TMPGEnc, I get the 2 seperate files, .m2v and .wav that have to be muxed in my authoring program.
So I mux (author) with DVD-lab and when I test the resulting VOB, the audio and video are out of sync (more so towards the end of the movie, of course).
To make things even more confusing, I have a similar AVI file with which I followed the same steps and it came out fine! No sync problems whatsoever. The only difference is that it was originally encoded with 44100 audio.
Is there something I should be doing differently with DVD creation than I was doing with VCD creation to ensure I get sync?
Are there some other settings that I should be paying attention to?
Thanks in advance,
Tim
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Sync problem
By ReGeN in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2010, 22:49 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
Sync Problem
By anirban in forum Newbie / General discussionsReplies: 8Last Post: 1st May 2008, 12:15 -
sync problem
By Madgelina in forum SubtitleReplies: 3Last Post: 1st Aug 2007, 14:29
