  1. Member videocheez's Avatar
    Jan 2003
    I have been using CCE2.67 with eclCCE since May and everything was working fine. I have encoded several avi to mpeg2 during this period. Today I tried to load CCE and the program never completely loaded. It only stayed on the taskbar and could not be maximized. I have done two things to my system during the last week that may have caused the problem. I installed and ran Gordian Knot for the first time which I believes uses avisynth 2.52, I had Avisynth 2.5 already installed on the system. I also ran a spybot prog to delete any spyware from the comp. I uninstalled cce and reinstalled and the prog will not run.
    I would obviously like to avoid the old format c: but I don't know what to do and i refuse to use TMPGE. Any help or advice will be greatly appreciated.
    Thanks in advance,
    VC
    This is so much fun!
  2. Same thing happend for me, not solved it yet
    Let me know if you come up with something.
  3. Ok
    *did an uninstall
    *deleted all i could find about custom technology/CCE in register
    *reinstall
    now it works.
