I have DVD-5 and DVD-9 burning down pretty well now, but now I have a Divx file I want to convert to MPEG-2. I read that with Divx it is better to separate the audio from the video for sync reasons.
I used VirtualDub to extract a wav file from the AVI, but how can I demux just the AVI with no audio?
"Can You Dig It!"
Go to audio and select no audio in v dub. Then go to video and select direct stream copy. Lastly, go to file and select save as avi. Give your avi a name and save it. This will give you an exact copy of your avi video without the audio.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
is there a way to do batch demuxing of avi files in virtualdub?
By Ankin in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 09:44 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Demuxing a "naked" vob to mpeg, m2v, etc
By engineer52 in forum Video ConversionReplies: 2Last Post: 13th May 2007, 16:39
