Results 1 to 15 of 15
  1. I just read the tutorial to do this with tmpgenc software, i did all steps fallowed in the tutorial then burnt it with nero 6.0 without multi sesion and played on my dvd but it didn't work, my dvd can read dvd-r (jvc xv 523), i don't know what am i doing wrong.
    can anyone please help? is there anothe way?
    thanks.
  2. anyone please?
    May 2003
    how did you burn it ...... you have to do dvd video in nero and not data disk
  4. i tried at first with dvd video but nero didn't find the file, so i burnt it as data.
    i used tmpgenc to encoded it from vcd to dvd and made a 4 gb file from 800mb.
    May 2003
    it wont work if you burn as data ..... what files do u have ... do you have a folder with .ifo .bup and .vob files
  6. i don't have any folder witn nothing, i have a file wich i can't bulieve what type is because when i click properties it won't tell what it is.
  7. where it says file type says only FILE
  8. Before Nero can burn your video to DVD it must first be authored. You will have an empty AUDIO_TS folder and a VIDEO_TS folder which will have files called ifo, bup, vob, etc. It will be these files that Nero recognizes when you try to burn to a DVD. When you use Nero you will drag the audio and video folders to the workspace in Nero to burn to disc.
  9. Actually i always knew that it was suppossed tb like that, i fallowed this tutorial https://www.videohelp.com/tmpgencdvd.htm, and it only resulted at the end in one file.
  10. Your link doesnt work but it sounds like you have used tmpgenc to encode a movie to dvd spec. You now need to use authoring software to turn the file you produced into the dvd folders containing the vobs etc recognisable by burning programs.
  11. The TMPG encoder will not author the mpg file for you. You need a specific program which is designed for that. There are many to choose from such as Ulead DVD Movie Factory, Sonic MyDVD, DVDLab, etc.
  12. here is the link again https://www.videohelp.com/tmpgencdvd.htm
    What software do you recommend and if there is any tutorial i'll be greatfull,
    thanks.
  13. I use Ulead DVD Movie Factory v.1 and DVD Lab. Both are excellent. There are guides on the left in the "how to author" section. Good Luck.
  14. one more thing, do i use tmpgenc first from vcd to dvd and then the new software? or directly from vcd to dvd with this new softwares?
    thanks
