I converted a DivX (high quality) to m2v format with TMPGEnc .
Now the problem I have is that when the movie changes scenes, the screen slightly turns purple.
Also, sometimes I don't see any colors, only black and white. Although the only settings I changed were :
MPEG Layer-2
Pal
720*576
4:3
25 FPS
Full screen (keep aspect ratio)
Which encoding settings did you use? Are you using VBR or CBR, or are you using the PAL DVD template with just the modifications you mentioned?
Damn that purple haze! Excuse me, while I kiss the sky...
sub/idx color Problem
By emfdom in forum SubtitleReplies: 7Last Post: 2nd May 2010, 21:44 -
Color problem after using deshaker
By lgh529 in forum EditingReplies: 5Last Post: 9th Aug 2009, 19:25 -
Color Playback Problem?
By magikalfly in forum Video ConversionReplies: 7Last Post: 18th Feb 2009, 23:14 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 21:16
