I want to burn a downloaded avi. file - I'm encoding via TMPEG Enc but the finished file has no audio, only video. Can anyone tell me what I'm doing wrong??? (I've tried clicking on the 'System - Video and Audio stream' option in TMPG but it didn't work...)
Cheers
This has occasionally happened to me. Usually it occurs because the intervleaved audio in the AVI uses a format not recognized by TMPGEnc.
SOLUTION: OPen up TMPGEnc, kill the wizard, select the AVI file using BROWSE, then go to FILE -> SAVE AS -> WAV FILE and choose a filename. (You can do nealry the same thing from VirtualDub if you prefer to use that tool.)
Now use BROWSE to replace the [filename].AVI as the audio source with [filename].WAV you just created. Encode as usual. You should get auiod with your video now.
This occurs in particular when I save as huffyuv AVI format, which I often do becuase I process videos with VirtualDub fairly often. Something about the audio itnerleaving in Rudiak-Gold's huffyuv AVI format makes TMPGEnc discard the audio, so I use this workaround, and have had no problems creating encoded MPEG-2s with audio from otherwise recalcitrant AVI files.
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 17:15
