Hi, I've got Matshita SW-9581-C, the processor is an Athlon 2600, 1G memory 150G hard disc.
I was only able to burn DVDs with Pinnacle Studio 8 using it's inbuilt DVD burner. I was never able to write discs with the supplied Expressions.
I downloaded a firmware upgrade from firmware-flash.com, when I installed it I was never given the option to save the old firmware (B100). It flashed it to B102, but this has made things even worse, now I can't burn any DVDs all it does is ruin the discs, it's even ruined a rewriteable!
I emailed the author, Arzeno for help on this matter, no reply (yet).
Can anyone tell me where to download the B100 version of the firmware?
I reinstalled the operating system Windows XP but this didn't help either.
I also tried a Pioneer 106D, but this just ruins discs as well, maybe it's just a coincidence. Dunno, but I'm really fed up.
All help gratefully accepted:
-Pete
H i Pete
I have this drive and have no problems with the new firmware
looking round the forums there are a lot of faulty drives i think that you have one as well.
Alan... -
Hi Alan,
Thanks for reply. Maybe it is faulty, however I still need to flash the firmware back to the original version in order to get it sorted out under warranty. Any ideas?
...Pete. -
This is great, 184 views and 3 replies (2 of which are mine!)
I think the problem is the fact that the so called system builders at Time have chosen to use FAT32 instead of NTFS, this means that it's only possible to capture a MAXIMUM of 18 minutes of video, or maybe it's because the Windows installation has been copied from a master hard disc (preinstalled), so everything is set to safe settings, great so you have to buy a 2600 Athlon to get the same performance as a 1200.
Take my advise don't buy anything from the computer shop (formerly known as The Computer World). Their after sales service is attrocious as is their extended warranties. BUILD YOUR OWN - you'll get less problems.
VAIO E series Matshita BD-CMB UJ141AS
By difoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Mar 2010, 19:56 -
Philips dvdr3590H, hardware clicks and almost ruins cd/dvds.
By aleks93 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Oct 2008, 01:16 -
Help with Matshita Drive/Adobe Encore V2
By bailout in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Aug 2007, 14:16 -
MPEG 2 Conversion to DV Video ruins aspect ratio
By dyoungiii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jul 2007, 19:59 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 05:11
