i actually posted this already but when i go onto the forum i cant find it so if ny1 does see it feel free to delete the spare one.thanks.
im having the following problem-svcd2dvdmpg was working fine previously but i havnt been able to get the new version working due to this error,i thought maybe it was a problem with new version so i switched back to old but then got the same error-ive used lots of diff sources files-.bins but no use,ive never been able to get mpegs to work either on a slightly unrelated problem,any help wud be gr8-regards,gsand:
Starting SVCD2DVD: v1.5.1326.35434
Begin time: 1:36:50 PM
******** Ripping SVCD images to get mpegs
7 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
Exception: STATUS_ACCESS_VIOLATION at eip=77F51BAA
eax=00000000 ebx=00000000 ecx=000007B0 edx=77E38190 esi=77E38180 edi=00000000
ebp=0022F074 esp=0022F000 program=
cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023
Stack trace:
Frame Function Args
0022F074 77F51BAA (00E38180, 77DD1715, 77E38180, 00000000)
0022F0D8 77F7561D (80000001, 61060CAA, 00000000, 610D3F98)
0022F118 61060F71 (0022F1A0, 80000001, 00020019, 0022F150)
0022F138 61060CA6 (0022F1A0, 80000001, 00020019, 61060CAA)
0022F168 61060D96 (0022F1A0, 00020019, 00000000, 77E7AC6F)
0022F1C8 610711B1 (0A000000, 0022F230, 0022F1F8, 61002724)
0022F1F8 6103D063 (615F0088, 0022F230, 0022F22C, 0000B808)
0022F348 61070F53 (610D1E98, 61006C8A, 77FC4D80, 77E61A57)
0022F398 610073E5 (610D1F58, FFFFFFFE, 000007E8, 610D1E7C)
0022F3E8 610076ED (003DD040, 00342318, 00342300, 5B430000)
0022F408 6100A31C (003D0000, 003DD040, 0000008C, 0022F4A4)
0022F438 003DAAD6 (003D0000, 003DA8FC, 00342300, 5B43ABFC)
0022F468 003DA96C (003D0000, 00000001, 00000000, 003DA920)
0022F488 77F7572A (003DA920, 003D0000, 00000001, 00000000)
0022F584 77F5A10A (00000000, 00000000, C0150008, 00000000)
0022F818 77F5AA2F (00000000, 00243D98, 0022FAEC, 0022FAE4)
End of stack trace (more stack frames may be present) 20412 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
20630 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
20890 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
21180 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
21584 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
21826 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
22089 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
22342 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
22578 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
22815 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
23054 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
23323 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
that goes on a long time but its the same so ill leave at that then i get:
231084 [unknown (0x300)] ? 516 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
231415 [unknown (0x300)] ? 516 handle_exceptions: Error while dumping state (probably corrupted stack)
231755 [unkn
can ny1 help me sort this out as im having no luck and it did work b4.regards,gsand.
can nobody help me with this?i have installed uninstalled etc etc with old version,+version and 1.5 to no luck,also it wont do menus now,another error.regards,gsand.
Can you Post your log file?
everything below that is what was came up on the log in notepad when i selected the option-there was a lot more but it was all the same so i didnt include so as to not waste space.
AVIsynth refuses to work anymore... Plz help!
By Nagashi in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2010, 17:44 -
Hello My dvd shrink 3.2 does not work anymore
By Seekyr in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2009, 19:14 -
Videos don't work anymore
By SINZAR in forum Software PlayingReplies: 5Last Post: 14th Mar 2008, 12:46 -
Decode with quicktime does not work anymore
By macuser1960 in forum ffmpegX general discussionReplies: 8Last Post: 16th Jan 2008, 04:21 -
Installed Vista, and Super does not work anymore? Any
By tzm in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 22:05
