Hi,
I have some TV shows that I recorded on DVD that I want to convert to VCD. BUT I have a problem.
Basically the route I use is: SmartRipper to DVD2AVI (creates a D2V and a WAV). Use the TMPGenc Plus wizard to create a VCD.
Simple stuff and worked perfectly until I upgraded to TMPGenc Plus Ver. 2.520 (2.520.54.163).
Now the VCD files are too big - twice the size they used to be!!!!
Can anyone help? Is there a setting I've missed??
Thanks folks.
Sounds like the bitrate setting is not set at the standard 1150. double check that and see if it has changed. If you're using the wizard, it should be locked at 1150, but if not, it could be different.
The bitrate is fixed to 1150. However, I just noticed that the Movie Info section describes the file as "90 min 09 sec" - double what I thought it is.
Just did a check and would you believe it, I ripped too many chapters. I was trying to convert 2 episodes.
User Error - doh!
Thanks for the suggestion andkiich - as always the helpfulness of the people here is awesome.
Latest version of Google Earth?
By alegator in forum ComputerReplies: 2Last Post: 15th Feb 2010, 18:38 -
what is the latest version for quicktime ???
By khalid81 in forum Software PlayingReplies: 2Last Post: 10th Jun 2009, 17:40 -
Latest Version of VLC
By Wanderlustus in forum Software PlayingReplies: 6Last Post: 20th Feb 2009, 12:47 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 13:55 -
Latest Version 2.5 & Problems with mpeg2 (files become too big) + AVI2M
By bc82 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 29th Jan 2008, 08:31
