Hey all,
I am using Adaptec CD Creator 5.0 to create VCD's to play on my Toshiba SD-2109Y but they won't work.
I wondered if anyone had any luck with this, maybe a particular brand of CD or something because I can play commercial VCD's just fine.
I don't know if this model is CD/R compatable or not.
Many thanks
Steve
I have a toshiba 3109 with the same problem, Compatibility list says it will work only with silver media, ever try to find silver media? the computer store guys look at you with a blank stare. Any body know which brand will work?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
The only CDRs that I have seen that may be silver are Memorex and Imation. Both are very reasonably priced. -
Old Samsungs are media sensitive too. I've finally found Princo 74s and Vivastar 80s that work for VCD but only 99% reliable. I get the occasional glitch. SVCD spins the CD faster and these are more unreliable. I'm at the point where I am about to ditch the Samsung for something that reads everything. Good luck
Have a Toshiba 2050 Frys brands of CD-R's, 8X looks exactly like the Dye in a CD-RW play great also some 8x or 12x Sony CD-R's will work also.
Plus its not exactly silver its more like meduim blue-silver.
flv convertions your help much appreciated!
By rotuts in forum MacReplies: 2Last Post: 12th Sep 2011, 09:22 -
Time to get a new PC-advise appreciated
By victoriabears in forum ComputerReplies: 23Last Post: 23rd May 2010, 13:20 -
Macintosh Software recommendation appreciated
By Montehall in forum MacReplies: 6Last Post: 14th Dec 2009, 22:39 -
BSOD, help would be appreciated.
By chipsndukes in forum ComputerReplies: 11Last Post: 27th May 2009, 20:06 -
dvd hack for lg ht353sd any help would be appreciated
By trickydicky663 in forum Newbie / General discussionsReplies: 1Last Post: 5th May 2009, 13:26
