  1. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I have some avi files I want to convert but I get a error in TMPGE saying avi file not supported or can not be opened. I have tried resetting the enviromental settings but I still get that error msg. Would anyone have some suggestions for me? I would appreciate any help. Thanks in advance.
  2. This has been coverd before, do a forum search and I'm sure you'll find the answer you're looking for.
  3. Make sure you have downloaded al the Divx codecs etc and goto environmental settings/VFAPI plugins make sure Direct Show s set to priority 4 this should sort it but as above do a search in the Forum its quite common.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Thanks for the advice. I dl the codecs and TMPGE works fine now.
