I have tried using the latest version when I go to the reauthor mode the existing files do not show up I then have to reload the movie and everything is the same I have used version 2.3 but can't get the latest version to work. Is there anything I ma doing wrong?
From my understanding, Shrink opens up a new window, and you drag over the titles from the window with the titles on it. At least thats how I've done it
Check out this thread https://www.videohelp.com/forum/viewtopic.php?t=173934
I tried the split window dragging over and had two main movie files which were 3,108 gig went to only 767 megs so where did the rest go. All the help place I found only show you how to use the older versions.
Where did you put them?Originally Posted by sporlan
I'm coming over to hold your hands.
Or just post the screenshoot of the two windows like I did so we could have a look at it.
I'd like to see the TITLES in Window1 and the TITLES in Window2You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
sporlan, I made a very rough guide to re-authoring with DVD Shrink v3.0 beta (as the final release will most likely have a different interface).
I don't know how much it will help as you seem to have done everything right.
http://www.dvdshrink.info/re-author-v3beta5.php
One cause of your problem might be the titles you dragged to the re-author window might have shared some of their content with other titles.
Try the "Combine shared titles" option in the "View" menu.
DVD Shrink structure problem
By janefield in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2010, 08:11 -
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
