Okay...I'm typing this for the 2nd time, so forgive me if I get to the point!
I'm attempting to transfering my dozen mini-DV home movie tapes over to DVD. Using Studio 8.8, I'm capturing without scene detection, and just adding a simple DVD menu and chapter marks. I'm then burning using Studio's encoder and DVD burner. Have found that my 1 hour DVD's are out of sync by about 1 second or so by the end. Even the avi file that Studio puts out has the same problem!
I'm using a P4 2.53GHz, 512MB, Firewire, 200GB dedicated capture drive. I've experienced no dropped frames (well, okay, zero on one tape, 2 on another, and 21 on the third).
What do I do? I'm open to other applications if this is one of many of Studio's issues. What should I be using to get my DV into my PC?
I'm ready to hook my camcorder up to my Hauppauge PVR-250 analog in and capture, as I've had success in keeping DVD's in sync if I create them with TMPGENC DVD Author.
Originally Posted by cz9h3d
If the original DV is in sync, copying it via firewire would keep it in sync. If that PS (pinical studio) software lets you use its firewire port with other sw, I'd try to capture via fire wire using a small tool like DVIO or winDV. Then check them out in virtualDub to see if they are in sync, and pick it up in your sw from there.
I've done the following to make DVD from minDV
- Capture using winDV
- Pick the clips I want (play them in VDub)
- join them in an avs script
- encode to mpeg using mainconcept
- author with maestro
This takes me about 2x the length of the movie (as long as I don't futz around with the menu too much)
PS: I don't know if anyone has ever made it thru an hour of my miniDV footage. Maybe there is a problem at the end -
BTW: DV specs do not require audio to be locked in sync with video. I believe this gives people problems if they do a lengthy passthru vcr-->dvcam-->pc. I would not think that this is your problem.
I had the same trouble. The problem I had was that Pinnacle Studio 8 only captures and handles Type 2 DV avi and apparently that is incompatible with my sony digital8 camera (TRV-740). I was able to successfully capture hours of DV using the WinDV tool and capturing in Type 1 DV (WinDV is a very handly piece of freeware that allows you to specify which type of DV you wish to capture and it can be found in the tools section of this site). Hope this helps and good luck.
- Smells_Like_Feet -
I never heard of out-of-sync problem with capturing from DV camcorder through FireWire port with Pinnacle Studio version 8 . (it doesn't mena that it does not exist) Is that what tou are doing ? DV capturing is just like "file copy". Do you still have that issue ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Sync issue - HD capture 250/mil off
By NotSoEasy in forum DVB / IPTVReplies: 4Last Post: 16th Mar 2012, 16:57 -
Virtualdub avi capture audio sync issues
By buckethead in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2011, 14:34 -
TV Capture with EasyCAP and VirtualDub Audio out of sync
By olobay in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 18:19 -
Capture out of sync after demux/remux (framedropping)
By Bingo-days in forum Capturing and VCRReplies: 3Last Post: 13th Jan 2010, 08:41 -
HELP! Trying to capture s-video and digital audio and sync them.
By laureynsr in forum Capturing and VCRReplies: 7Last Post: 24th Dec 2008, 21:56
